[Geoserver-devel] accessing URL parameters
i have a good functioning data store derived from org.geotools.data.store.ContentDataStore. i can put features on a map in geoserver. woot! thanks for the help getting here. :slight_smile:
now i'm trying to get access to parameters on the http get for the map from URLS like this:
http://localhost:8080/geoserver/wms?service=WMS&version=1.1.0&request=GetMap&layers=us-woot&styles=&bbox=-124.731,24.956,-66.97,49.372&width=780&height=330&srs=EPSG:4326&format=application/openlayers&foooooooo=baaaaaaaaaaar
is it possible to get access to "foooooooo"/"baaaaaaaaaaar" values way down in ContentDataStore?
thanks,
  -trebor
Normally you would parse the “key value pairs” into a map and pass that into your datastore constructor. (Or in your constructor do the parsing).
On Thu, Jun 30, 2011 at 9:44 AM, Robert Harris <trebor@anonymised.com> wrote:
now i’m trying to get access to parameters on the http get for the map from URLS like this:
is it possible to get access to “foooooooo”/“baaaaaaaaaaar” values way down in ContentDataStore?
thanks,
-trebor
All of the data generated in your IT infrastructure is seriously valuable.
Why? It contains a definitive record of application performance, security
threats, fraudulent activity, and more. Splunk takes this data and makes
sense of it. IT sense. And common sense.
http://p.sf.net/sfu/splunk-d2d-c2
Geotools-devel mailing list
Geotools-devel@anonymised.coms.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
i assume this would happen in my implementation of DataStoreFactorySpi as that is what constructs my data store. two problems:
  1. i can't figure out how to get a hold of the url data to parse up. do you know how i would get that data?
  2. i think doing this in the factory is too early for my needs. my goal is to be able to pass parameters to my data store from the client. do you know if that is possible?
thanks for the help so far,
  -trebor
On Jun 29, 2011, at 5:52 PM, Jody Garnett wrote:
Normally you would parse the "key value pairs" into a map and pass that into your datastore constructor. (Or in your constructor do the parsing).
thanks,
-trebor
Geotools-devel@lists.sourceforge.net
Well the client code is mostly in those initial connection parameters; and also when they make a Query.
Perhaps you could talk a bit more about what you are trying to accompish; right now the conversation is difficult for me as you are asking about ContentDataStore; but trying to use a GetMap request.
Perhaps you are asking GetMap to produce a small shapefile or sqlite database or something crazy which you can work with offline?
There is a Query “hint” map that can be used to pass random information in - but if is something that all code has to do then you would be in trouble. The rendering system won’t know to pass in some magic hints that you always require for example.
Jody
On Thu, Jun 30, 2011 at 11:58 AM, Robert Harris <trebor@anonymised.com> wrote:
  1. i can’t figure out how to get a hold of the url data to parse up. do you know how i would get that data?
-trebor
thanks,
-trebor
my setup:
i'm running an instance of geoserver into which i have installed my custom ContentDataStore. that store provides a layer of features which is composited together with other layers to produce a lovely map - which i can view by hitting that url (way down near the bottom of this thread). my custom store actually makes a call out to yet other service, which provides feature data to me in a very non-standard form. i also have a custom client which can add parameters, as needed, to the map url. in my particular case the client needs to indicate which feature data the backing service emits (as well as some authentication data).
i can't figure out how to get ahold of the parameters in the url (which i can see geoserver has, as it reports them in it's log) in my data store. would a hint help geoserver pass specific parameters down to my code?
  -trebor
There is a Query "hint" map that can be used to pass random information in - but if is something that *all* code has to do then you would be in trouble. The rendering system won't know to pass in some magic hints that you always require for example.
Jody
-trebor
> thanks,
> -trebor
i'm digging through doc and code now on hints, and vender options. if i get stuck i'll head over towards geoserver-devel (which i've added back onto this thread).
you've been a huge help. thank you!
  -trebor
On Jun 29, 2011, at 8:00 PM, Jody Garnett wrote:
Okay that is what the hints are for; but you need to look into the geoserver-devel mailing list and source code to see how the hints are handled.
From the geotools side of things:
a) I would view the "feature generalized" work as a good example of this where some explicit hints were defined; and the rendering system taught to use them in order to control the function of the the datastore.
b) GeoServer may also have some way to explicitly handle "vendor options" which it could pass down into the datastore as hints. As a client author I like to ask that vendor options are actually defined up front in the get capabilities document but this rarely happens).
Jody
On Thu, Jun 30, 2011 at 12:32 PM, Robert Harris <trebor@anonymised.com> wrote:
my setup:
-trebor
> Jody
> -trebor
> > thanks,
> > -trebor
> > _______________________________________________
ok, i'm stumped. i can't figure out how to get parameters in a geoserver wms getmap URL pushed down into my ContentDataStore.
here is the URL i've been using.
  http://localhost:8080/geoserver/wms?service=WMS&version=1.1.0&request=GetMap&layers=us-woot&styles=&bbox=-124.731,24.956,-66.97,49.372&width=780&height=330&srs=EPSG:4326&format=application/openlayers&env=foobar:baz&namespace=fred.com&format_options=rabbit:cat
as you can see i've tried putting my own values at the end of the URL in env, namespace, and format_options, but i think i need to some how hint that i want this information passed into my store.
i suspect that if i did things properly, i could have some those values present int the query when:
  ContentFeatureSource.getReaderInternal(Query query)
is called. looking at the Hints class it's not clear to me how i might signal interest in say the "env" values from my ContentDataStoreFactory. any ideas?
   -trebor
ps - as you can see Jody Garnett had some clues, but i appear to be thick enough to be unable to work it out non-the-less.
-trebor
Jody
my setup:
-trebor
Jody
-trebor
thanks,
-trebor
On Thu, Jun 30, 2011 at 8:01 AM, Robert Harris
GeoServer has a path to send down info to the stores via the view
params of parametric sql views:
http://docs.geoserver.org/latest/en/user/data/sqlview.html
If you add &viewparams=p1:v1;p2:v2;.... into your request the
datastore will receive a data access
request with a Query containing, among its Hints at the
Hints.VIRTUAL_TABLE_PARAMETERS key,
a hash map with the p1, v1, p2, v2 pairs.
This should fit your needs if all you need is read only behavior
changes, and will keep the datastore
GeoServer agnostic (the same params can be passed down by any other
kind of application).
If you need something more generic and are willing to marry the store
1-1 to GeoServer
you can also use the org.geoserver.ows.Dispatcher.REQUEST thread local,
that one will contain the request and the various stages of its
parsing, including the raw
kvp, the parsed kvp, the parsed request object and so on.
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
that worked great. "click your heels together three times and say..." :slight_smile:
thank you!
  -trebor
Better yet; submit a documentation patch that includes that information for the next person :slight_smile:
Jody Garnett
If you add &viewparams=p1:v1;p2:v2;… into your request the
that worked great. “click your heels together three times and say…” :slight_smile:
thank you!
-trebor
Geoserver-devel mailing list
agreed! i'm not sure how/where that would go. the problem being that it is already documented (in some sense). when i saw this section:
and discarded it because it appeared to be sql specific. any suggestions on how/where i could mod the docs that adds signal without too much noise?
  -trebor
Jody Garnett
thank you!
-trebor
Interesting; would could add it as an example in the geotools docs … to the datastore tutorial when we are introducing Query.
ie. Query hints are used to pass in extra information from the calling application. As an example this GeoServer getmap query …
Jody
On Fri, Jul 1, 2011 at 2:42 AM, Robert Harris <trebor@anonymised.com> wrote:
agreed! i’m not sure how/where that would go. the problem being that it is already documented (in some sense). when i saw this section:
-trebor
Jody Garnett
thank you!
-trebor
On Thu, Jun 30, 2011 at 6:42 PM, Robert Harris <trebor@anonymised.com> wrote:
I guess a section in the developer guide for those that want to develop data stores working in GeoServer could
be the place. It’s not there, but could be created easily by pointing at the geotools data store and adding
a few GeoServer specific extras, like the virtual table param things.
If you get that started I could add details such as how the store factory params are
used to build a GUI, how to build a custom config panel for a store
Ing. Andrea Aime
Tech lead
