I managed to get a “light” paralellization during the catalog load by rolling a background
thread pool that would take care of loading the xml files into memory, without having
to parallelize the code that runs in the spring startup.
Basically, the existing code does a number of “scan this directory for xml files and load them
one by one”, that’s the part I parallelized by creating a asynch iterator doing the loading,
and giving the main thread a byte for each file, to decode and put int the catalog.
The benefit of doing so is visible because IO is the bottleneck.
So, let’s see some numbers, but before, a reminder of the data dirs involved:
- “Many states”: 1 workspace, 1 store, 10k layers, 10k cached layers
- “Large”: 1001 workspaces, 11000 stores (a mix of shapefiles, postgis, directory of shapefile, single tiff, arcgrid, mosaics), 42000 layers and 42000 associated tile layers
Here is a comparison of the last loading times I have vs the ones with parallel IO loading.
- Many states, cold startup. Before, 68s. After: 30s
- Many states, warm startup. Before: 29s After: 21s
- Large, cold startup. Before: 230s After: 107s
- Large, warm startup: Before: 45s After: 45s (weird?)
As expected the benefit shows up mostly on col startups, where actual IO against the disk happens (btw, the
IO is likely happening against the SSD cache of my hybrid HD, a pure spinning disk drive will likely have worse timings).
Pull request available here, please let me know if anybody wants to review or if you have reservations
against a merge (plan B, land it after the freeze and wait September to have it in a release):
https://github.com/geoserver/geoserver/pull/2116
PS: the IO rate I see is still quite a bit below the potential of my local drive, so a true
parallelization of the catalog loading (including the CPU bound part) is likely to reap extra
benefits, but as said previously, it’s harder to implement. This is a more modest approach that
still manages to provide a speedup.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
