[Geoserver-devel] Activating full wms support in integrated GWC
as you may remeber Nicola did some work in GWC to improve
the fullwms performance and output quality.
Now, in GeoServer integrated gwc we still have the fullwms
protocol inactive:
FALSE
Wondering, since it’s now working better, shall we activate it instead,
by flipping the above flag to true in geowebcache-wmsservice-context.xml ?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
The FullWMS improvements allow for FullWMS to be set on a layer by layer basis right? So is this loading the module so that the layers can then use it, or changing the default so all layers are using FullWMS?
Making it available sounds good but I’m not sure I like the idea of having it turned on by default.
On 23 July 2014 02:39, Andrea Aime <andrea.aime@anonymised.com> wrote:
protocol inactive:
FALSE
Ing. Andrea Aime
@geowolf
Technical Lead
Want fast and easy access to all the code in your enterprise? Index and
search up to 200,000 lines of code with a free copy of Black Duck
Code Sight - the same software that powers the world’s largest code
search on Ohloh, the Black Duck Open Hub! Try it now.
http://p.sf.net/sfu/bds
Geoserver-devel mailing list
Kevin Smith
Junior Software Engineer | Boundless
ksmith@anonymised.com
+1-778-785-7459
@boundlessgeo
http://boundlessgeo.com/
