[Geoserver-devel] Add a process to geoserver 2.1.0 wps extension build failed
I am now trying to add a process to geoserver 2.1.0 wps extension. But I don’t know how to build the wps extension alone. I tried to use maven to build the source code under “%geoserver-src%\extension\wps\wps-core”. But it failed and I couldn’t find the jar package. Could someone help me about that? I also do not know how to debug the wps-core if I change its code. Should I have to build that again by maven?
don't know how to build the wps extension alone. I tried to use maven to
build the source code under "%geoserver-src%\extension\wps\wps-core". But it
failed and I couldn't find the jar package. Could someone help me about
The answer to both questions is that you have to build the whole GeoServer,
not just the WPS module. That will give you also a simple debug
enviroment, look at the Start class in the web/app module.
Also look at the developer guide, it will give you pointers on how
to build GeoServer from sources.
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
