ebru
June 14, 2013, 8:54am
1
I use geoserver 2.3.2 and tomcat 7 and follow the steps in this
link:http://docs.geoserver.org/stable/en/user/data/raster/gdal.html .
After completing the steps I had new raster data sources below.
<http://osgeo-org.1560.x6.nabble.com/file/n5060109/gdalcreate.png> ;
but i couldnt add .ecw( ERDAS Compressed Wavelets) file like a store to
geoserver . What did i wrong.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Add-ecw-ERDAS-Compressed-Wavelets-file-format-to-geoserver-tp5060109.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
If you ask on the users mailing list, you may get a response.
Jonathan
On 14 June 2013 09:54, ebru <ebrubasrn@anonymised.com > wrote:
<http://osgeo-org.1560.x6.nabble.com/file/n5060109/gdalcreate.png >
Sent from the GeoServer - Dev mailing list archive at Nabble.com .
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
Geoserver-devel mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Ciao,
it looks like the ECW plugins hasn't been loaded.
Question, which operating system are you working on?
Anyway, if you browse inside the native libs there are link to the
gdalinfo executable. Run it with --formats t check that the plugin is
loaded.
You may also want to play with the GDAL_DRIVER_PATH environment
variable in case you are on windows.
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Fri, Jun 14, 2013 at 10:54 AM, ebru <ebrubasrn@anonymised.com> wrote:
