Hey,
it seems the adding a feature type is broken for me in 1.7.x. When I create a
datastore and try to add a feature type, both for shapefile and arcsde, is
fails with an exception like:
java.lang.NullPointerException
at
org.vfny.geoserver.action.data.TypesEditorAction.sync(TypesEditorAction.java:403)
at
org.vfny.geoserver.action.data.TypesEditorAction.executeSubmit(TypesEditorAction.java:565)
at
org.vfny.geoserver.action.data.TypesEditorAction.execute(TypesEditorAction.java:130)
at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
at
org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
Could anyone confirm before I fill a bug report?
Gabriel
Gabriel Roldan
OpenGeo - http://www.opengeo.org
I fixed an issue involving an NPE on line 403 yesterday; how recent is
your checkout?
I will be doing some testing and polish on geosearch tomorrow, so I can
investigate this issue as well if 'svn up' doesn't fix it.
-d
On Fri, 2009-01-16 at 21:08 -0200, Gabriel Roldan wrote:
Hey,
at
at
at
at
Gabriel
I just tried and could not replicate with an up to date checkout. Added both a shapefile and postgis feature type ok.
Hey,
it seems the adding a feature type is broken for me in 1.7.x. When I create a datastore and try to add a feature type, both for shapefile and arcsde, is fails with an exception like:
at org.vfny.geoserver.action.data.TypesEditorAction.sync(TypesEditorAction.java:403)
at org.vfny.geoserver.action.data.TypesEditorAction.executeSubmit(TypesEditorAction.java:565)
at org.vfny.geoserver.action.data.TypesEditorAction.execute(TypesEditorAction.java:130)
at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
Gabriel
Justin Deoliveira
OpenGeo - http://opengeo.org
I see there's already a thread on the matter: "Geoserver 1.7.x bug when adding
a new featuresTypes from UI"
Dave, had you a chance to look at it yet?
I'm worries since we're going for 1.7.2 and can't add a FT from the ui
cheers,
gabriel
On Friday 16 January 2009 21:08:36 Gabriel Roldan wrote:
Hey,
at
a:403) at
ction.java:565) at
java:130) at
org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101) at
ssor.java:431)
Gabriel
Gabriel Roldan
your checkout?
its of yesterday. And so please forget my last message, this one came over
just after I sent the other one asking you.
Gabriel
-d
> Hey,
> at
>ava:403) at
>rAction.java:565) at
>n.java:130) at
>cessor.java:431)
> Gabriel
Gabriel Roldan
