[Geoserver-devel] Add "manual Layers"
I'm completely new to GeoServer, and I have the following task:
I need to create a Map with an additional Layer (one that is not in the
actual WMS-Service).
This additional Layer could be created from a list of vertices (e.g. in case
of a route) or a shapefile
(e.g. a user generated catchment area).
How can I do this?
My approach is, to create a "DefaultWebMapService" to call the WMS-Service
and add the "manually created" Layer, but how can I do this?
And is this the right way?
Another question is: what's the best Docu to get started ?
The APIDOC is nice, but when I doen't know, what the Objects are for, it's
hard to get into the whole thing.
Thanks
Bernhard Gruber
___________________________________
WIGeoGIS
Vienna - Munich
Bernhard Gruber
Application developer Web
Hansalg. 3, A-1030 Wien
Fon +43 (1) 715 19 87-20
Fax +43 (1) 715 19 87-99
e-mail: bg@anonymised.com
http://www.wigeogis.at
Hi Bernhard,
It sounds like what you are wanting to do is add layers dynamically? Without going through the user interface? If that is the case we use the REST configuration API for this.
http://docs.geoserver.org/1.7.x/user/extensions/rest/index.html
There are some examples there that show how to upload a shapefile.
-Justin
Bernhard Gruber wrote:
How can I do this?
Another question is: what's the best Docu to get started ? The APIDOC is nice, but when I doen't know, what the Objects are for, it's
Thanks
Bernhard Gruber
WIGeoGIS Vienna - Munich
Bernhard Gruber
The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
production scanning environment may not be a perfect world - but thanks to
Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
Series Scanner you'll get full speed at 300 dpi even with all image processing features enabled. http://p.sf.net/sfu/kodak-com
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
