[Geoserver-devel] Adding a multidimensional extension to WMTS (as a GeoServer community module, with integrations with GWC own WMTS).
I’m currently working on a extension/profile of WMTS (and eventually WMS) that allows
clients to better interact with a dataset having multiple dimensions, eventually scattered,
eventually correlated, providing tools to discover where the pockets of data are in
a large potential ND space.
The extension is written down as a spec of sorts, but it’s not a OGC spec, if you are curious
you can read it here:
http://demo.geo-solutions.it/share/wmts-multidim/wmts_multidim_geosolutions.html
Now, given this is nothing official I want to keep it in a community module.
And given it’s about deep understanding of the dimensions structure, and requires custom fast
data access to get all the min/max/histograms, I want to keep it
in GeoServer, where all the tools to recognize layer types and query dimensions are
available.
Now, what I need to do in order to add support for the extension is:
  • Add support for dimensions in the WMTS caps document. Dimensions are a native concept in WMTS, but they are limited to a full enumeration of possible values (you can read more about it in the doc above).
  • Add extra operations to the protocol (typical of a profile), by declaring them in the caps document and then having a way to dispatch them when invoked
  • (Optional) Add REST extension to WMTS… ok, this can be done directly in GWC, just not sure right now if it will fit. If added, the caps document will need to contain URL templates for the new operations, too
For the first, I would suggest to extend TileLayer with a method to discover the dimensions:
getDimensions() → Map<String, Dimension>
where Dimension would be a bean reporting the WMTS description of a dimension, that is, providing name, title, abstract, default value and list of values.
Given the limited usefulness of the full enumeration approach against large domains, I’m inclined to just return the list of values as a List, if one has troubles keeping it in memory, the caps document is toast anyways, but I’m open to other alternatives, like a closeable iterator of sorts (we have one in GeoServer, but it’s not available in GWC).
The default implementation would just return an empty map, the GeoServerTileLayer would look for a TileDimensionProvider interface returning such map, with no default implementation (to keep things easy for the moment), and the community module would provide an implementation of it.
In order to extend the protocol instead, I’d propose to have a WMTSExtension interface in GWC following the same spirit as
the GeoServer extended capabilities providers, but with the extra ability to dispatch a request, something like:
interface WMTSExtension {
/* --------- Pretty much as the geoserver own extended caps providers here -------- */
String getSchemaLocations(String schemaBaseURL);
void registerNamespaces(NamespaceSupport namespaces);
public abstract void encodeExtendedOperations(
org.geoserver.ExtendedCapabilitiesProvider.Translator tx, WCSInfo wcs,
GetCapabilitiesType request) throws IOException;
  • Interface for clients to encode XML.
    public interface Translator {
  • Starts an element creating the opening tag.
  • @param element The name of the element.
    void start(String element);
  • Starts an element with attributes, creating the opening tag.
  • @param attributes The attributes of the element.
    void start(String element, Attributes attributes);
  • Creates a text node within an element.
  • @param text The character text.
    void chars(String text);
  • Ends an element creating a closing tag.
  • @param element
    void end(String element);
/** ------------- Dispatching the extra requests here, working like a GWC Service object -------------------- **/
public Conveyor getConveyor(HttpServletRequest request, HttpServletResponse response)
throws GeoWebCacheException, OWSException;
public void handleRequest(Conveyor conv) throws OWSException;
If there are no objections I’ll turn this into a GWC proposal next week.
Now, the only thing I’m a bit concerned about is Kevin’s availability and ability to type… Kevin, if you can use any voice
communication we can setup a voice meeting, chat about this, and I’ll transcribe your feedback for everybody else
to read.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
+1 to create the GeoServer community module.
Kind regards,
Ben.
On 30/05/16 22:25, Andrea Aime wrote:
I'm currently working on a extension/profile of WMTS (and eventually WMS)
that allows
data are in
The extension is written down as a spec of sorts, but it's not a OGC spec,
if you are curious
module.
And given it's about deep understanding of the dimensions structure, and
dimensions are
available.
   - Add support for dimensions in the WMTS caps document. Dimensions are a
   - Add extra operations to the protocol (typical of a profile), by
   when invoked
   - (Optional) Add REST extension to WMTS... ok, this can be done directly
getDimensions() -> Map<String, Dimension>
of values.
domains, I'm inclined to just return the list of values as a List<String>,
anyways, but I'm open to other alternatives, like a closeable iterator of
sorts (we have one in GeoServer, but it's not available in GWC).
In order to extend the protocol instead, I'd propose to have
<https://github.com/geoserver/geoserver/blob/master/src/main/src/main/java/org/geoserver/ExtendedCapabilitiesProvider.java&gt;,
here -------- */
WCSInfo wcs,
     * Interface for clients to encode XML.
         * Starts an element creating the opening tag.
         * @param element The name of the element.
         * Starts an element with attributes, creating the opening tag.
         * @param attributes The attributes of the element.
         * Creates a text node within an element.
         * @param text The character text.
         * Ends an element creating a closing tag.
         * @param element
If there are no objections I'll turn this into a GWC proposal next week.
Now, the only thing I'm a bit concerned about is Kevin's availability and
ability to type.... Kevin, if you can use any voice
communication we can setup a voice meeting, chat about this, and I'll
to read.
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
Geoserver-devel mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Hi Ben,
thanks for the +1 for the community module.
I got no feedback on the proposed changes to the GWC WMTS module… shall I just
go ahead and write a proposal there? I also re-iterate my availability for a voice meeting:
to read.
There is a reasonable window around 9-10 am Vancouver time that still overlaps with
my normal office hours:
http://www.timeanddate.com/worldclock/meetingtime.html?iso=20160608&p1=215&p2=256
On Mon, May 30, 2016 at 9:45 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Kind regards,
Ben.
that allows
data are in
if you are curious
module.
dimensions are
available.
    when invoked
of values.
<https://github.com/geoserver/geoserver/blob/master/src/main/src/main/java/org/geoserver/ExtendedCapabilitiesProvider.java>,
here -------- */
WCSInfo wcs,
  • @param element
to read.
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Jun 7, 2016 at 7:00 AM, Andrea Aime <andrea.aime@anonymised.com>
wrote:
Hi Ben,
I got no feedback on the proposed changes to the GWC WMTS module... shall
I just
a voice meeting:
Sorry for the slow turnaround, looking at it right now. At a first glance
it looks ok but doing a more in depth review FWIW
Gab
to read.
overlaps with
Kind regards,
Ben.
that allows
data are in
spec,
if you are curious
module.
dimensions are
available.
are a
them
   when invoked
directly
document
list
of values.
large
List<String>,
for
it.
providers
here -------- */
WCSInfo wcs,
         * @param element
a
to read.
traffic
are
planning reports.
Director
New Zealand
Ing. Andrea Aime
@geowolf
Technical Lead
traffic
are
Geowebcache-devel mailing list
Geowebcache-devel@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geowebcache-devel
Gabriel Roldán
Software Developer | Boundless <http://boundlessgeo.com/&gt;
groldan@anonymised.com
@boundlessgeo <http://twitter.com/boundlessgeo/&gt;
ok, here’s my 2 cents.
Having almost no experience with multidimensional datasets myself I can barely speak of the approach (in regard to the protocol extension), though in general it looks totally sensible.
  • Ranges: wonder if it’d make sense to have an open/closed boundes/unbounded range syntax (check Guava’s Range javadocs for a possible syntax as reference [1])
  • Will an open source client be provided as well? e.g. an OL3 extension?
  • Implementation wise, have you considered writing a separate WMTS service instead of extending the rather dumb GWC one? (especially when it comes to XML encoding, it still uses ad-hoc string building instead of any actual XML API).
    Also, the “protocol extension profile” approach can work, but wonder if you would have more freedom by defining it as separate service, lets say DWMTS of sorts. In any case I’d advise not to care about GWC public service API as much as possible and restrict development to a GeoServer plugin where it is actually possible to implement this (by means of GeoServerTileLayer/LayerInfo introspection?). I’m mentioning this cause perhaps during the initial definition of the extension it may seem pretty solid for the specific use cases at hand, but as a protocol extension is might need further validation against other unforeseen cases. And probably a separate service would give you more freedom to experiment and evolve without having to worry about non official WMTS versions (you can’t just version it 1.0.something). In any case, the point is whatever the approach (1.0 extension profile or new service), I feel it’d be easier (in terms of flexibility and freedom) for you if you could just avoid the whole WMTSExtesion thing and focus on doing your business confined to a Geoserver plugin?
Sorry I only have questions though.
Gabriel
[1] <https://google.github.io/guava/releases/17.0/api/docs/com/google/common/collect/Range.html>
On Thu, Jun 9, 2016 at 10:17 AM, Gabriel Roldan <groldan@anonymised.com> wrote:
On Tue, Jun 7, 2016 at 7:00 AM, Andrea Aime <andrea.aime@anonymised.com68…> wrote:
Hi Ben,
Sorry for the slow turnaround, looking at it right now. At a first glance it looks ok but doing a more in depth review FWIW
Gab
to read.
Gabriel Roldán
@boundlessgeo
Kind regards,
Ben.
that allows
data are in
if you are curious
module.
dimensions are
available.
    when invoked
of values.
here -------- */
WCSInfo wcs,
  • @param element
to read.
Director
New Zealand
Ing. Andrea Aime
@geowolf
Technical Lead
Gabriel Roldán
@boundlessgeo
On Tue, Jun 14, 2016 at 3:30 PM, Gabriel Roldan <groldan@anonymised.com>
wrote:
ok, here's my 2 cents.
- Ranges: wonder if it'd make sense to have an open/closed
boundes/unbounded range syntax (check Guava's Range javadocs for a possible
I did consider this, but turned it out as the range syntax already in use
in WMS does not have such an option, and the subsequent
best practice documents do not seem to complain about the lack of it.
- Will an open source client be provided as well? e.g. an OL3 extension?
It's not yet certain if we are going to write a client at all, another
group might be building it.
If we build a demo I don't see a problem in releasing it, but I don't think
it's going to be a OL3 extension (it would be a good idea, I just don't
think we'll have the time to go there).
- Implementation wise, have you considered writing a separate WMTS service
XML API).
Yes, I went back and forth a number of times on the idea, but I don't like
the outlook for the future and the amount of code duplication.
For example, we might consider adding WMTS REST support too along with it
(still out on the drawing board), but there is definitely no time to work
it twice.
Long story short, if we work in a fork, nothing of the improvements we
might make is going to come back to core in the short term, and might
eventually be lost.
I prefer instead to work and add extension points allowing to add more
operations also in the future.
Ing. Andrea Aime
@geowolf
Technical Lead
