[Geoserver-devel] Adding a new "generic" built-in style
Hi folks,
as you know, in GeoServer we have four built-in styles, “point”, “line”, “polygon”, “raster”,
that GeoServer automatically associates to layers based on their geometry type.
I was considering adding a fifth built-in one, “generic”, which would paint the right
symbolizer based on the geometry’s nature, to be used when we have no clue of
what geometry type we’re dealing with.
It would be something like this one:
http://docs.geoserver.org/2.6.x/en/user/styling/sld-tipstricks/mixed-geometries.html#geometrytype-function
It would be nice to have a simpler function to use, something like isLinear, isPolygonal, instead
of listing all geometry types… I guess it would still fail for geometry collections though.
Maybe we could have a getPoints/getLines/getPolygons
functions instead, that would be used to extract the right bits from the data own geometry,
which would make it work even with the contents of a geometry collection, tearing it apart
in its constituent pieces.
Opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Sounds like a great idea to me. I’m always seeing questions about why do my polygons come out as points?
Ian
On Wed, 13 May 2015 11:36 am Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi folks,
Opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y_______________________________________________
Geoserver-devel mailing list
May be able to make use of SemanticTypeIdentifier (and “generic:line”, “generic:polygon”, “generic:point”, “generic:text”, “generic:raster”).
On 13 May 2015 at 02:35, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi folks,
Opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
+1
This is only for vector data, right?
Mauro
2015-05-13 11:35 GMT+02:00 Andrea Aime <andrea.aime@anonymised.com>:
Hi folks,
Opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, May 14, 2015 at 10:03 AM, Mauro Bartolomeoli <
maurobartolomeoli@anonymised.com> wrote:
+1
Thankfully we don't have mixed vector/raster data sources yet :slight_smile:
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, May 13, 2015 at 11:37 PM, Jody Garnett <jody.garnett@anonymised.com>
I don't think SemanticTypeIdentifier is meant to be used that way. Going
from the javadocs of FeatureTypeStyle:
     * The SemanticTypeIdentifiers is experimental and is intended to be
used
     * to identify, using a community-controlled name(s), what the style is
     * suitable to be used for.
     * For example, a single style may be suitable to use with many
     * different feature types. The syntax of the SemanticTypeIdentifiers
     * string is undefined, but the strings "generic:line_string",
     * "generic:polygon", "generic:point", "generic:text",
     * "generic:raster", and "generic:any" are reserved to indicate
     * that a FeatureTypeStyle may be used with any feature type
     * with the corresponding default geometry type (i.e., no feature
     * properties are referenced in the feature type style).
     * <p>
     * This method will be replaced by a live set semanticIdentifiers() in
2.6.x
     * @return An array of strings representing systematic types which
     * could be styled by this instance.
     * @deprecated this method is replaced by a live set
So, it seems to me, we could mark our point style as "generic:point" (and
so on for the others),
the one I'm talking about could be marked as "generic:any" (well sort of,
it would not cover raster).
That said, this is a label to identify what a style is suitable for, not as
a filtering tool inside the style (which was 99% of the
content of my first mail, how do we make the style generic in the first
place)... so an extra semantic
bit, but not a solution. Wondering, do you know anything (dunno, a client)
that's going to use SemanticTypeIdentifier?
Ing. Andrea Aime
@geowolf
Technical Lead
pull requests here:
https://github.com/geotools/geotools/pull/842
https://github.com/geoserver/geoserver/pull/1070
On Wed, May 13, 2015 at 11:35 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi folks,
Opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
