[Geoserver-devel] Adding a new "generic" built-in style
Could it be enough to check the dimension of the geometry (0,1,2) instead of exact geometrytype?
Just this week Michaël Michaud implemented a geometry type constraint to OpenJUMP based on the dimensions of the features:
return feature.getGeometry().getDimension() == dimension;
But this may not be enough if geometrycollections can’t be handled.
-Jukka Rahkonen-
Andrea Aime wrote:
Hi folks,
as you know, in GeoServer we have four built-in styles, “point”, “line”, “polygon”, “raster”,
that GeoServer automatically associates to layers based on their geometry type.
I was considering adding a fifth built-in one, “generic”, which would paint the right
symbolizer based on the geometry’s nature, to be used when we have no clue of
what geometry type we’re dealing with.
It would be something like this one:
http://docs.geoserver.org/2.6.x/en/user/styling/sld-tipstricks/mixed-geometries.html#geometrytype-function
It would be nice to have a simpler function to use, something like isLinear, isPolygonal, instead
of listing all geometry types… I guess it would still fail for geometry collections though.
Maybe we could have a getPoints/getLines/getPolygons
functions instead, that would be used to extract the right bits from the data own geometry,
which would make it work even with the contents of a geometry collection, tearing it apart
in its constituent pieces.
Opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Wed, May 13, 2015 at 1:19 PM, Rahkonen Jukka (MML) <
jukka.rahkonen@anonymised.com> wrote:
That's also a nice idea, better than checking the type names like in the
example in the docs... but still would not work for generic geometry
collections, which can include
a mix of the 3 types (JTS for geometry collections is going to pick the
largest, meaning a mix of point lines and polys will be drawn as polygons,
by closing
the lines from end to start to form a polygon, and ignoring the points).
Wondering how commons the generic collections are in the real world, maybe
we can just ignore them.
Yep, see above
Ing. Andrea Aime
@geowolf
Technical Lead
Sounds like an excellent idea to me.
Re: generic collections. Well I think there are real world examples but because most software is useless at handling mixed geometry, modellers automatically abstract into multiple geometry classes and then battle to maintain topological correctness. Anyone dealing with active seismic knows of the hassles in maintaining shotpoint location features (a point and line object) in GIS software. I believe city modellers battle similar issues with water/tap, power line/pole/transformer geometries.
Notice: This email and any attachments are confidential.
If received in error please destroy and immediately notify us.
Do not copy or disclose the contents.
