[Geoserver-devel] Adding a new method to the GeoServerLifecycleHandler interface
I’m proposing we add a new method to the GeoServerLifecycleHandler interface:
  • Called when a reload is starting, see onReload for a notification that the reload ended
    void beforeReload();
The method will allow implementors to do special actions during the reload period,
and the implementation in GeoServerImpl will make sure once beforeReload() is
called, a call to onReload() is guaranteed().
Use cases for this method:
  • interact with a custom servlet filter that will block all incoming ogc requests
    during the reload (they will likely fail anyways)
  • notify load balancers and put the node temporary out of the pool
The change will affect all implementations of GeoServerLifecycleHandler and break them, of course all
the ones in GeoServer will be fixed. Given this, no attempt to backport the change will be made
(GeoServerLifecycleHandler is after all a pluggable interface, everybody can implement
it and use it custom extensions).
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Sounds good to me, +1
On Wed, Jun 11, 2014 at 10:17 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
HPCC Systems Open Source Big Data Platform from LexisNexis Risk Solutions
Find What Matters Most in Your Big Data with HPCC Systems
Open Source. Fast. Scalable. Simple. Ideal for Dirty Data.
Leverages Graph Analysis for Fast Processing & Easy Data Exploration
http://p.sf.net/sfu/hpccsystems
Geoserver-devel mailing list
Justin Deoliveira
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive
On Wed, Jun 11, 2014 at 6:22 PM, Justin Deoliveira <
And here comes the pull request:
https://github.com/geoserver/geoserver/pull/617
Ing. Andrea Aime
@geowolf
Technical Lead
