[Geoserver-devel] Adding another repository reference
as per http://jira.codehaus.org/browse/GEOS-3063
I would like to add a XHTML validation check in our
unit tests using
http://github.com/dashorst/wicket-stuff-markup-validator/tree/master
which is hosted in a repository here:
http://wicketstuff.org/maven/repository/org/wicketstuff/htmlvalidator/1.2/
However, adding another repo reference is going to slow down builds.
Not that much if I specify not to check it for snapshots, but still,
it may be annoying.
What do you think, worth it?
Alternatives:
- don't make xhtml compliance checks
- push this jar to the opengeo repo
Let me know
Andrea Aime
OpenGeo - http://opengeo.org
Andrea Aime wrote:
unit tests using
it may be annoying.
Alternatives:
I think putting into our repo should be fine right? After you have the jar locally it should be one liner with mvn install:install-file to put into the repo.
Let me know
Justin Deoliveira
I'd be for pushing to OpenGeo. I'm already doing that for H2.
-Arne
Andrea Aime wrote:
unit tests using
it may be annoying.
Alternatives:
Let me know
Arne Kepp
