[Geoserver-devel] Adding CoverageStore from REST & admin/loadFromXML.do issue
Hi devs,
just few things I noticed when I was working with REST for adding
CoverageStore...
Here I described how I refresh my Coverage:
http://www.nabble.com/Reload-Mosaic-CoverageStore-Coverage-after-shp-properties-file-has-been-modified-td23928766.html#a23998686
Through REST I delete coverage store, coverage and then I PUT it again.
It works well, coverage information are updated, but thers one
problem. The shape file doesnt get updated, until I reload geoserver
store with admin/loadFromXML.do as described here:
http://geoserver.org/display/GEOSDOC/Alternative+for+reloading+the+Geoserver+catalog
I guess it is because shape file is loaded into memory, and REST
doesnt do neccessary things to update the shape file.
Bug? Should I open issue for that?
By the way, I noticed that admin/loadFromXML.do doesnt require any
permission, anybody can reload store?
Bug or feature? Ill open an issue if somebody tells me to.
And just one little correction to REST docs: (dont have knowledge with
spynx still, so if someone can change it, tnx)
http://docs.geoserver.org/1.7.x/user/extensions/rest/rest-config-api.html
- coverage store part: under extensions file[.<extension>] -> mosaic
should be changed to imagemosaic
Ivan Grcic
Ivan Grcic wrote:
Hi devs,
CoverageStore...
So I guess this is specific to the mosaic plugin? Not sure exactly what happens. I can try to look into it. Simone?
You are correct, indeed you do not, definitely a bug I would think, although i have been wrong before. I would open an issue in the tracker for it though.
Good catch. Thanks. I just updated the docs. And if you are interested in helping out with docs we can get you access.
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Justin,
I opened issues on those…and about documentation, yup im interested so if you could give me access would be nice. I already have some JAVA REST examples to put there :wink:
Regards
On Tue, Jul 14, 2009 at 2:23 AM, Justin Deoliveira <jdeolive@anonymised.com1501…> wrote:
Ivan Grcic wrote:
Hi devs,
CoverageStore…
for it though.
  • coverage store part: under extensions file[.] → mosaic
Justin Deoliveira
Enter the BlackBerry Developer Challenge
This is your chance to win up to $100,000 in prizes! For a limited time,
vendors submitting new applications to BlackBerry App World™ will have
the opportunity to enter the BlackBerry Developer Challenge. See full prize
details at: http://p.sf.net/sfu/Challenge
Geoserver-devel mailing list
Ivan Grcic
Cool, contribution to the docs would be much appreciated. Usually we prefer to have people submit patches before handing them out commit access.
http://docs.geoserver.org/1.7.x/developer/policies/comitting.html
So you could contribute the first round of doc updates via a patch, which we can review. We can then get you commit access to commit directly. Although even when you do have commit access the patch/review process is still very valuable, and one we try to stick to when we can.
-Justin
Ivan Grcic wrote:
Hi Justin,
I opened issues on those..and about documentation, yup im interested so if you could give me access would be nice. I already have some JAVA REST examples to put there :wink:
Regards
On Tue, Jul 14, 2009 at 2:23 AM, Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>> wrote:
    Ivan Grcic wrote:
     > Hi devs,
     > just few things I noticed when I was working with REST for adding
     > CoverageStore...
     > Here I described how I refresh my Coverage:
     > Through REST I delete coverage store, coverage and then I PUT it
    again.
     > It works well, coverage information are updated, but thers one
     > problem. The shape file doesnt get updated, until I reload geoserver
     > store with admin/loadFromXML.do as described here:
     > I guess it is because shape file is loaded into memory, and REST
     > doesnt do neccessary things to update the shape file.
     > Bug? Should I open issue for that?
     > By the way, I noticed that admin/loadFromXML.do doesnt require any
     > permission, anybody can reload store?
     > Bug or feature? Ill open an issue if somebody tells me to.
    for it though.
     > And just one little correction to REST docs: (dont have knowledge
    with
     > spynx still, so if someone can change it, tnx)
     > - coverage store part: under extensions file[.<extension>] -> mosaic
     > should be changed to imagemosaic
     > Regards,
    Justin Deoliveira
    vendors submitting new applications to BlackBerry App World(TM) will
    have
    full prize
    <mailto:Geoserver-devel@lists.sourceforge.net>
Ivan Grcic
Enter the BlackBerry Developer Challenge This is your chance to win up to $100,000 in prizes! For a limited time, vendors submitting new applications to BlackBerry App World(TM) will have
the opportunity to enter the BlackBerry Developer Challenge. See full prize details at: http://p.sf.net/sfu/Challenge
Justin Deoliveira
