[Geoserver-devel] Adding CQL filtering at the layer level configuration
in this mail I’m proposing we resurrect an old functinality we had at the 1.7.x times,
filtering layers by a user specified filter.
The FeatureTypeInfo filter field is indeed still there:
https://github.com/geoserver/geoserver/blob/master/src/main/src/main/java/org/geoserver/catalog/FeatureTypeInfo.java#L61
but the code around it is kind of lacking, and need some massaging and deep testing to make
sure it actually works, since nothing in that area has been touched in several years.
GUI wise we need a way to edit the filters, which I’m proposing is going to be a simple text field for the moment,
that will show up below the attribute list, and which will validate checking both syntax and proper usage of
existing attributes in the layer.
Persistence wise, we need to have XStream store the Filter (right now there are no converters for them, which
would make for a non useful storage), which I’m proposing to store as ECQL too.
We’ll then have to verify that the filtering machinery works at the GeoServerFeatureSource level, and that
it mixes well with user, style and security filters.
The impetus to work on this originates from simplifying and at the same time generalizing the SORL store
usage (see related mail in GeoTools devel),
dropping the attribute based layer mapping, and replacing with a more general CQL filter that
will also allow the same document to show up in multiple layers, but the functionality is general and will
be useful in other cases too.
Meet us at the INSPIRE Conference in Lisbon 25-29 May 2015! Visit http://goo.gl/WHKDXT for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Andrea,
This is a technical comment/question rather than a note about the main proposal. (The proposal overall seems sensible to me.)
As you work with and store the ECQL filter, are you going to need ECQL.toFilter/ECQL.toCQL to be inverses? I’ve seen a few cases where that doesn’t work out completely. (And I’ve tried to help submit patches as I learn about them.)
Anyhow, maybe that’s not necessary; figured I’d mention it.
Jim
On 05/20/2015 05:43 AM, Andrea Aime wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
[http://ad.doubleclick.net/ddm/clk/290420510;117567292;y](http://ad.doubleclick.net/ddm/clk/290420510;117567292;y)
Geoserver-devel mailing list
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
On Wed, May 20, 2015 at 7:56 PM, Jim Hughes <jnh5y@anonymised.com> wrote:
Andrea,
ECQL.toFilter/ECQL.toCQL to be inverses? I've seen a few cases where that
doesn't work out completely. (And I've tried to help submit patches as I
learn about them.)
I'm aware, but I guess we'll cross that river when necessary. I don't think
it's a big deal if the syntax changes, provided
the semantic of the filter remains the same. Or not?
Ing. Andrea Aime
@geowolf
Technical Lead
The times I’ve run into it, ECQL.toCQL has produced a string which cannot be parsed by ECQL.toFilter.
If you carried around the original input string, you’d be set. For us, we’ve played rewriting filters and that’s when things have gotten exciting.
JIm
Andrea,
I’m aware, but I guess we’ll cross that river when necessary. I don’t think it’s a big deal if the syntax changes, provided
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, May 20, 2015 at 8:14 PM, Jim Hughes <jnh5y@anonymised.com> wrote:
The times I've run into it, ECQL.toCQL has produced a string which cannot
If you carried around the original input string, you'd be set. For us,
we've played rewriting filters and that's when things have gotten exciting.
Hi Jim,
in the end we've followed your advice and kept the CQL unparsed, to
generate the Filter representation
on the fly.
It's part of this pull request:
https://github.com/geoserver/geoserver/pull/1128
In particular, this commit:
https://github.com/aaime/geoserver/commit/3654db29f94360a378693868e0c4fd5d62a21f2f
Ing. Andrea Aime
@geowolf
Technical Lead
