[Geoserver-devel] adding data to geoserver via some code in java
I want to add some .tif images to geoserver but not through GUI provided in
it.I want to write a code in java which will take the path of image as input
and will save the data in geoserver.how can I do this?also can I do this
sitting on a remote server?
View this message in context: http://www.nabble.com/adding-data-to-geoserver-via-some-code-in-java-tp23920703p23920703.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
You should be able to do this with the REST api extension, without writing any code. Check out:
http://docs.geoserver.org/1.7.x/user/extensions/rest/
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
