[Geoserver-devel] Adding extension in the build by default?
you probably know that a build without parameters in GeoServer would cause only the core modules
to build, but not the extensions, which can be included with “-Prelease”.
However, is there anyone around not building extensions? Wondering if “-Prelease” should be on by
default, and have an ability to turn it off explicitly instead, like -P!release
Opinions?
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I would be okay with that, extensions build by default and release.
Does release include any of the community modules?
Jody Garnett
As far as I know community modules are included by communityRelease only.
+1 for building by default whit extensions.
I need to play with some Maven echo messages plugins (like echo) to see if outputting
some info during the build, or simply point to the build documentation will
help keep tracks of all the profiles, build command we have :slight_smile:
Jody Garnett
+1 from me
Ian
Ian Turton
