[Geoserver-devel] Adding shapefile datastore to geoserver via restful interface
I am trying to add a shapefile datastore to a geoserver 2.0.2 instance. I have been able to get it to work using the following command
curl -u admin:geoserver -v -XPUT -H ‘Context-type: application/zip’ --data-binary ‘/home/path/to/test.zip’ http://localhost:8080/geoserver/rest/workspaces/sf/datastore/sf/file.shp
However I already have the shape files stored in a particular directory and I simply want to reference them. When I try the following command which I was told by a guy in the open-geo booth at FOSS4G-2010 it gives me an error.
curl -u admin:geoserver -v -XPUT -H ‘Content-type: text/plain’ -d ‘/home/path/to/test.shp’ http://localhost:8080/geoserver/rest/workspaces/sf/datastores/sf/external.shp
  • About to connect() to localhost port 8080 (#0)
  • Trying ::1… connected
  • Connected to localhost (::1) port 8080 (#0)
  • Server auth using Basic with user ‘admin’
PUT /geoserver/rest/workspaces/sf/datastores/sf/external.shp HTTP/1.1
Authorization: Basic YWRtaW46Z2Vvc2VydmVy
User-Agent: curl/7.19.7 (i486-pc-linux-gnu) libcurl/7.19.7 OpenSSL/0.9.8k zlib/1.2.3.3 libidn/1.15
Host: localhost:8080
Accept: /
Content-Length: 20
< HTTP/1.1 400 Bad Request
< Transfer-Encoding: chunked
< Server: Jetty(6.1.8)
  • Connection #0 to host localhost left intact
  • Closing connection #0
    Could not determine format. Try setting the Content-type header.
It is supposedly telling me that the text/plain content type is unknown but I can’t get any other combination other then application/zip to work.
Can anyone say what I’m doing wrong or is what I’m trying to do not posible and I need to program my own restful interface to do it.
John
I posted this question yesterday with no replies. Is it that few use the restful interface, and I should just work out my own solution, or did I post it to the wrong list.
John
On Thu, Sep 23, 2010 at 10:13 AM, John Preston <byhisdeeds@anonymised.com> wrote:
Accept: /
Content-Length: 20
John
Generally we encourage users of the REST API to ask on the users list (you’d have to be working with the actual code of GeoServer to cross over into -devel territory). I think the REST API is used by a relatively small number of people compared to those who use GeoServer in general, but the ‘upload a shapefile’ use case is pretty typical of what those users are doing. However, I don’t believe the REST API supports uploading non-zipped shapefiles right now. If it did, you would need to provide at least the .shp, .dbf, and .shx files; the .shp is not sufficient by itself.
There are actually multiple things wrong with your sample request (posting a single .shp file without the accompanying .shx and .dbf, using text/plain for the mimetype, using PUT when you want to create a new object), so I expect most developers on this list were too busy with other work to break it down here.
David Winslow
OpenGeo - http://opengeo.org/
On Fri, Sep 24, 2010 at 12:38 PM, John Preston <byhisdeeds@anonymised.com> wrote:
John
Accept: /
Content-Length: 20
John
Start uncovering the many advantages of virtual appliances
and start using them to simplify application deployment and
accelerate your shift to cloud computing.
http://p.sf.net/sfu/novell-sfdev2dev
Geoserver-devel mailing list
