we have discussed a couple of times already about the use of “aws s3 cp”, and the issue
with old stale files being left on the server when a module graduates.
Just by accident I’ve found this command, “aws s3 sync”:
https://docs.aws.amazon.com/en_us/cli/latest/userguide/cli-services-s3-commands.html#using-s3-commands-managing-objects-sync
Seems like a:
aws s3 sync --delete localDir s3://myBucket
would do what we need… with a caviat:
“s3 sync updates any files that have a size or modified time that are different from files with the same name at the destination.”
Hum… so the issue is that we’d need to keep a local copy that is not fully overwritten by the build, ensuring only that modified
files get actually updated. Maybe a local rsynch can do that?
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
