[Geoserver-devel] All nightly builds gone from 2.1.x on gridlock?
what happened here?
http://gridlock.opengeo.org/geoserver/2.1.x/
It seems the extensions are built, but the actual GS bin/war are gone?
Compare with trunk nightly builds, which do work fine:
http://gridlock.opengeo.org/geoserver/trunk/
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
It appears a mistake was made back on the 27th of June probably
related to testing maven 3. I have corrected this and run the nightly
again to verify - somewhere it's night right now ;).
Thanks for the heads up and sorry it took a bit to get to.
-Ian
On Thu, Jul 7, 2011 at 8:53 AM, Andrea Aime
<andrea.aime@anonymised.com> wrote:
what happened here?
Ing. Andrea Aime
Tech lead
All of the data generated in your IT infrastructure is seriously valuable.
Why? It contains a definitive record of application performance, security
threats, fraudulent activity, and more. Splunk takes this data and makes
sense of it. IT sense. And common sense.
http://p.sf.net/sfu/splunk-d2d-c2
Geoserver-devel mailing list
Ian Schneider
OpenGeo - http://opengeo.org
On Fri, Jul 8, 2011 at 8:47 PM, Ian Schneider <ischneider@anonymised.com1501…> wrote:
again to verify - somewhere it’s night right now ;).
Thank you for fixing it! :slight_smile:
Ing. Andrea Aime
Tech lead
