The idea of this work is to allow WMTS requests per workspaces (virtual services), something like this:
curl "http://localhost:8080/geoserver/topp/gwc/service/wmts?SERVICE=WMTS&REQUEST=GetTile&VERSION=1.0.0&LAYER=states&STYLE=pophatch&FORMAT
=image/png&TILEMATRIXSET=EPSG:900913&TILEMATRIX=EPSG:900913:3&TILEROW=3&TILECOL=1" -o /tmp/tile.png -D -
curl ' http://localhost:8080/geoserver/topp/gwc/service/wmts?REQUEST=GetCapabilities’ -o /tmp/wmts-capabilities.xml
This two request will be executed in the context of 'topp' workspace, which means that we don't need to prefix layer names with the
workspace prefix and only layers that belong to 'topp' workspace will be considered. The GetCapabilities operation result will only
advertise layers that belong to 'topp' workspace and layers names will not be prefixed by the workspace name. The advertised operations
URLs will keep the workspace context.
Since GWC doesn't have the concept of workspaces (a tile layer name is just a name) and adding that concept will require some work a simple
approach is to let GeoServer handle the local workspace parameter.
The idea is that GeoServer ConfigCatalog will be aware of the local workspace and will only list\show layers that belong to the local
workspace and before sending the request to GWC dispatcher we rewrite the request in the way GWC is expecting it (layer names prefixed with
the workspace name and no workspace in the path). This will be completely transparent to GWC.
The only change that needs to be done in GWC is to allow a TileLayer to return an advertised name (by default this method will return the
layer name). This will allow GeoServerTileLayer to override the getAdvertisedName() method and return the non prefixed layer name if a local
workspace is present. The WMTS get capabilities operation will invoke getAdvertiseName() method to obtain the name that should be used to
advertise the layer.
Any opinions on this ?
Nuno Oliveira
Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
mob: +39 333 8128928
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono
da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate
nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e
-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai
The information in this message and/or attachments, is intended solely for the attention and use of
the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree
June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying,
distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named
addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the
information in this message that has been received in error. The sender does not give any warranty or accept liability as the content,
accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which
arise as a result of e-mail transmission, viruses, etc.
