Build Information
- 2.1.0
- 15809
- 11-May-2011 20:09
- 2.7.1 (rev -1)
Revision -1 ?
Jody Garnett
Build Information
Revision -1 ?
Jody Garnett
On Fri, May 13, 2011 at 1:17 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Build Information
Version2.1.0
Subversion Revision15809
Build Date11-May-2011 20:09
GeoTools Version2.7.1 (rev -1)Revision -1 ?
GeoTools was likely built with git, the svn revision plugin
could not find the svn revision as a result, thus returned -1
The build server uses svn so it does not incur in the same problem
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Actually in this case it was not… gt was built from svn and the svn tag so not sure why the svn info did not get populated… i will try to investigate.
On Fri, May 13, 2011 at 6:10 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Build Information
Version2.1.0
The build server uses svn so it does not incur in the same problemCheers
Andrea–
Ing. Andrea Aime
Tech leadVia Poggio alle Viti 1187
Italyphone: +39 0584 962313
fax: +39 0584 962313http://www.geo-solutions.it
Achieve unprecedented app performance and reliability
What every C/C++ and Fortran developer should know.
Learn how Intel has extended the reach of its next-generation tools
to help boost performance applications - inlcuding clusters.
http://p.sf.net/sfu/intel-dev2devmay
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
