[Geoserver-devel] An interesting proposal in GeoNetwork land
just stumbled upon this one:
https://github.com/geonetwork/core-geonetwork/wiki/Java-7-NIO-File
Even if the GeoServer build is not nearly as slow as the one described in GeoNetwork (a full build with extensions takes 18 minutes for me on a dated desktop PC),
I’m wondering if we could benefit from a similar approach
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Andrea
This is interesting. I am building on 4.0 Ghz cpu (8 cores but only one is used) , having 32 MB Ram and an SSD. The command
time mvn clean install -PallExtensions -fn
results in
real 37m38.270s
user 58m15.900s
sys 1m44.293s
Ho do you manage a build in 18 minutes ?
The Geonetwork approach sounds interesting, doing all the setup in a memory file system.
On Sun, Nov 16, 2014 at 10:17 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Comprehensive Server Monitoring with Site24x7.
Monitor 10 servers for $9/Month.
Get alerted through email, SMS, voice calls or mobile push notifications.
Take corrective actions from your mobile device.
http://pubads.g.doubleclick.net/gampad/clk?id=154624111&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
On Sun, Nov 16, 2014 at 2:18 PM, Christian Mueller <
christian.mueller@anonymised.com> wrote:
Hi Andrea
results in
real 37m38.270s
user 58m15.900s
sys 1m44.293s
I don't know? I assumed it was the operating system, as with a core i7 3rd
generation, 8GB of ram and a 512GB SSD,
but using Windows, I build in 28 minutes instead. However, that's a
notebook.
However... I assume you're on Linux too, so not sure. One signicant
difference is that I build with -T2, and with that
much RAM you have (I assume it's 32GB, not MB, right?) you could easily try
with -T4
Maybe it's the distro? Last week I tried with an Ubuntu 12.04 64bits, and
got 18 minutes, today I'm on Linux Mint 17
and I'm building in 18 minutes too (upgraded OS, same hardware, first
generation core i7 820, 8GB memory,
2TB hybrid hard drive with 32 GB of integrated SSD acting as a cache).
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Andrea
By the way, my full build command is:
mvn clean install -T2 -nsu -Prelease
This assumes that you also have a fresh local GeoTools build, which in my
experience is
worth having since fetching the jars from the net is going to be slower
than doing a "mvn clean install -T4 -Dall -DskipTests"
locally to build the latest and greatest)
Ing. Andrea Aime
@geowolf
Technical Lead
This presumably locks you into Java 7? (not a problem for me).
Notice: This email and any attachments are confidential.
If received in error please destroy and immediately notify us.
Do not copy or disclose the contents.
I understand the motivation behind the approach but looks unnecessarily complicated to me.
We do something similar in GeoGig with a different approach, that IMHO is saner.
The thing is to always use a Junit 4 TemporaryFolder
For example:
class SomeTest{
@anonymised.com
public TemporaryFolder tmpDir = new TemporaryFolder();
@anonymised.com
public void setUp(){
File baseDir = tmpDir.getRoot();
setUpTest(baseDir);
And that’s all. The TemporaryFolder will clean up itself when the test finishes.
Whether it runs on /tmp, ${project.dir}/target, or any other path is a matter of parametrizing a maven property:
${project.build.directory} ... org.apache.maven.plugins maven-surefire-plugin ..... ${test.tmpDir}
</plugin
Then run mvn clean install -Dtest.tmpDir=/dev/shm, or wherever you have a ram disk mounted.
The difficulty with both the geotools and geoserver builds is that a lot of tests create temporary directories/files directly inside the project’s “target” directory.
They both also leave a lot of dangling files on /tmp (or wherever java.io.tmpdir points to). This has been a problem on the build server before, as they accumulate and can exhaust the filesystem.
I think it’d be a better fix for the geoserver unit tests code base to avoid such manual creation of temporary folders under target and rely on TemporaryFolder.
2c/
Gabriel
On Sun, Nov 16, 2014 at 10:18 AM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Hi Andrea
results in
real 37m38.270s
user 58m15.900s
sys 1m44.293s
On Sun, Nov 16, 2014 at 10:17 AM, Andrea Aime <andrea.aime@anonymised.com.1268…> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Gabriel Roldán
Software Developer | Boundless
groldan@anonymised.com
@boundlessgeo
On Mon, Nov 17, 2014 at 1:29 PM, Gabriel Roldan <groldan@anonymised.com>
ram disk mounted.
Eh, I thought about it, but not sure I have enough RAM on my machines to
actually dedicate a portion of it
to a RAMDISK (8GB are starting to be pretty tight these days, especially
with 150+ projects loaded in Eclipse
and the occasional virtual machine running).
Do you have an idea of how big of a RAM disk we'd need? Would a few hundred
MB work?
I guess I could stand up one during the build, and have it been tear down
when the build ends
Ing. Andrea Aime
@geowolf
Technical Lead
On Linux you don’t need to set up a ramdisk with a fixed size. Instead, mount it as tmpfs and it’ll be dynamic and fall back to swap space if need be <http://en.wikipedia.org/wiki/Tmpfs>
At ares.boundlessgeo.com we have it like this in /etc/fstab
tmpfs /mnt/memtmp tmpfs size=512m,nosuid,rw,auto,nouser,sync,relatime,mode=01777 0 0
And the geogig build is configured to run mvn clean install -Dtest.tmpDir=/mnt/memtmp
On Mon, Nov 17, 2014 at 10:21 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Mon, Nov 17, 2014 at 1:29 PM, Gabriel Roldan <groldan@anonymised.com> wrote:
Eh, I thought about it, but not sure I have enough RAM on my machines to actually dedicate a portion of it
to a RAMDISK (8GB are starting to be pretty tight these days, especially with 150+ projects loaded in Eclipse
Do you have an idea of how big of a RAM disk we’d need? Would a few hundred MB work?
I guess I could stand up one during the build, and have it been tear down when the build ends
Ing. Andrea Aime
@geowolf
Technical Lead
Gabriel Roldán
@boundlessgeo
On Mon, Nov 17, 2014 at 2:36 PM, Gabriel Roldan <groldan@anonymised.com>
wrote:
On Linux you don't need to set up a ramdisk with a fixed size. Instead,
mount it as tmpfs and it'll be dynamic and fall back to swap space if need
be <http://en.wikipedia.org/wiki/Tmpfs&gt;
Good information. Do you know if there is anything similar for Windows?
Trying this out should not be too hard, we have a single class managing the
test data directory used in our system tests.
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Nov 17, 2014 at 10:57 AM, Andrea Aime <andrea.aime@anonymised.com>
I know there are third party programs that allow to create a ramdisk. Never
used one myself, but a google search for "windows ramdisk" throws up a good
number of hits. I'm guessing most/all of them will be fixed size ramdisks,
though I could be wrong.
the test data directory used in our system tests.
Yeah that might get you 80% through. Plan ahead for non-standard set ups
headaches though.
Gabriel
Ing. Andrea Aime
@geowolf
Technical Lead
Gabriel Roldán
Software Developer | Boundless <http://boundlessgeo.com/&gt;
@boundlessgeo <http://twitter.com/boundlessgeo/&gt;
One note on the maven flags:
By using -T 2C (not just T2), you get 2*number-of-cores parallelism. This really speeds up all the leaf dependencies.
On an Ubuntu 14.04 notebook, i7-4700MQ w/ 16GB and a 5400RPM spinning disk :slight_smile:
time mvn clean install -T 2C -nsu -Prelease
real 13m7.575s
user 63m5.532s
sys 2m15.360s
On Sun, Nov 16, 2014 at 7:15 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Sun, Nov 16, 2014 at 2:18 PM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Hi Andrea
This assumes that you also have a fresh local GeoTools build, which in my experience is
worth having since fetching the jars from the net is going to be slower than doing a “mvn clean install -T4 -Dall -DskipTests”
Ing. Andrea Aime
@geowolf
Technical Lead
Ian Schneider
Software Engineer | Boundless
ischneider@anonymised.com
1-877-673-6436
@boundlessgeo
We are already on Java 7- you can drop Path use in behind ResourceStore … but it may not strictly be required. I already tried using ResourceStore with in-memory Mocking and it was quick.
On Sun, Nov 16, 2014 at 1:17 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Ciao Andrea,
although as you know I am in favour of using latest NIO features more
and more I am a bit concerned by the extent of this change which might
potentially mean a lot of work as well as a lot of instabilities.
Do you have a rough idea about the effort for this and also how would
you think this change should plan/conducted?
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
desktop PC),
I'm wondering if we could benefit from a similar approach
Ing. Andrea Aime
@geowolf
Technical Lead
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
On Tue, Nov 18, 2014 at 6:22 PM, Simone Giannecchini <
simone.giannecchini@anonymised.com> wrote:
Ciao Andrea,
No, honestly I did not look much into it, I've only seen the proposal and
said "hey, this might be useful for GeoServer as well".
What Gabriel proposed could be quite a bit easier to try out, althought
of course it requires some changes at the OS level, which on Linux seem
harmless, on Windows might be a bit annoying or just not feasible if you
don't have a lot of RAM.
Ing. Andrea Aime
@geowolf
Technical Lead
Wouldn’t virtualizing the file system (using NIO) during testing also mask windows file locking problems?
On Tue, Nov 18, 2014 at 11:05 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Download BIRT iHub F-Type - The Free Enterprise-Grade BIRT Server
from Actuate! Instantly Supercharge Your Business Reports and Dashboards
with Interactivity, Sharing, Native Excel Exports, App Integration & more
Get technology previously reserved for billion-dollar corporations, FREE
http://pubads.g.doubleclick.net/gampad/clk?id=157005751&iu=/4140/ostg.clktrk
On Tue, Nov 18, 2014 at 6:22 PM, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Ciao Andrea,
No, honestly I did not look much into it, I’ve only seen the proposal and
said “hey, this might be useful for GeoServer as well”.
don’t have a lot of RAM.
Ing. Andrea Aime
@geowolf
Technical Lead
Ian Schneider
1-877-673-6436
@boundlessgeo
On Tue, Nov 18, 2014 at 7:10 PM, Ian Schneider <ischneider@anonymised.com>
wrote:
Wouldn't virtualizing the file system (using NIO) during testing also mask
That's a good point. Except that as painful as they are, I blieve
we want to see these issues, because these lock also happen in production
and can break normal functionality
Ing. Andrea Aime
@geowolf
Technical Lead
Right - should have been clearer that masking problems is a bad thing :slight_smile:
So… the question is: does the windows tmpfs equivalent also lock files? (I’d guess yes)
On Tue, Nov 18, 2014 at 11:23 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Tue, Nov 18, 2014 at 7:10 PM, Ian Schneider <ischneider@anonymised.com> wrote:
That’s a good point. Except that as painful as they are, I blieve
Ing. Andrea Aime
@geowolf
Technical Lead
Ian Schneider
ischneider@anonymised.com…3839…
1-877-673-6436
@boundlessgeo
On Tue, Nov 18, 2014 at 7:27 PM, Ian Schneider <ischneider@anonymised.com>
So... the question is: does the windows tmpfs equivalent also lock files?
(I'd guess yes)
Eh don't know. Just got Windows back on the notebook after some years of
being
free of that hell... got a bit out of touch, it's only just as ugly as I
remembered it...
Ing. Andrea Aime
@geowolf
Technical Lead
