TLDR: Mauro a change you made Sep 19th broke cite tests on master. Are you able to fix for the scheduled release tomorrow?
Jody Garnett
Jody Garnett
Hi Jody,
if I remember correctly, the fix was done as an addition the FOSS4G sprint attempt to upgrade to a new version of the cite tests.
My question is: did we ever upgrade?
If not, probably the fix to this failing test is simply reverting it (it was just adding a question mark to a url, so we only need to remove it).
Mauro
2015-01-19 6:27 GMT+01:00 Jody Garnett <jody.garnett@anonymised.com>:
We have two cite failures a WCS cite failure (see other email thread) and a WFS 1.1 cite failure.
- ant wfs-1.1-log
- grep Failed
[exec] Test wfs:wfs-main (wfs-1.1.0) Failed (Inherited Failure)
[exec] Test wfs:readiness-tests (wfs-1.1.0/d41e34700_1) Failed (Inherited Failure)
[exec] Test wfs:basic-main (wfs-1.1.0/d41e34700_1/d41e749_1) Failed (Inherited Failure)
[exec] Test wfs:run-GetCapabilities-GET (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24740_1) Failed (Inherited Failure)
[exec] Test wfs:wfs-1.1.0-Basic-GetCapabilities-tc9.2 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24740_1/d41e853_1) Failed
[exec] Test wfs:wfs-1.1.0-Basic-GetCapabilities-tc16.5 (wfs-1.1.0/d41e34700_1/d41e749_1/d41e24740_1/d41e930_1) Failed- ‘[’ 0 == 0 ‘]’
- RETURN=1
- echo RETURN=1
RETURN=1
I am not quite sure what to make of this one?
Checking history - when did this start failing …
Failed > Console Output #345 Sep 20, 2014 4:40:46 PM
Success > Console Output #344 Sep 19, 2014 4:40:52 PM
So a week after the foss4g sprint working on cite tests.
Lets see what was happening on master about then:
Success > Console Output #792 Sep 21, 2014 3:29:15 PM
Success > Console Output #791 Sep 19, 2014 2:22:44 PM
So we have a suspect:
Here are the details…
Build #791 (Sep 19, 2014 2:22:44 PM)
Changes
GEOS-6675: workaround fix for wfs 1.1 cite tests failures (detail)
GEOS-6675: generalized fix to be applied always, not only for cite-tests and restricted to HTTP GET (detail)
Started by an SCM change
Revision: 763f20fe66c5e445b08241a0148b546bcad77ff3
origin/master
Here is the summary of the changes:
Summary
GEOS-6675: workaround fix for wfs 1.1 cite tests failures (details)
GEOS-6675: generalized fix to be applied always, not only for cite-tests and restricted to HTTP GET (details)
Commit e4dc4e829b885bd8b022fe265afd5a51cdee4773 by maurobartolomeoli
The file was modified src/wfs/src/main/java/org/geoserver/wfs/CapabilitiesTransformer.java
Commit 9f09639262dcc73a9f6220e607f56c82400f3117 by maurobartolomeoli
Jody Garnett
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
Based on your fix causing a test failure I am assuming we never upgraded.
On 19 January 2015 at 00:09, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com> wrote:
Hi Jody,
if I remember correctly, the fix was done as an addition the FOSS4G sprint attempt to upgrade to a new version of the cite tests.My question is: did we ever upgrade?
Mauro
Jody Garnett
- ant wfs-1.1-log
- grep Failed
- RETURN=1
- echo RETURN=1
RETURN=1
Changes
origin/master
Summary
Jody Garnett
@mauro_bart
It’s not a problem for me to revert it.
Should I do it?
Mauro
2015-01-19 9:23 GMT+01:00 Jody Garnett <jody.garnett@anonymised.com>:
Jody
Jody Garnett
Hi Jody,
Mauro
2015-01-19 6:27 GMT+01:00 Jody Garnett <jody.garnett@anonymised.com403…>:
- ant wfs-1.1-log
- grep Failed
- RETURN=1
- echo RETURN=1
RETURN=1
Changes
origin/master
Summary
Jody Garnett
@mauro_bart
@mauro_bart
Please do so, and if we can kick the CITE build I should have a clear shot tomorrow morning.
Jody
@mauro_bart
Jody Garnett
Hi Jody,
Mauro
- ant wfs-1.1-log
- grep Failed
- RETURN=1
- echo RETURN=1
RETURN=1
Changes
origin/master
Summary
Jody Garnett
@mauro_bart
Reverted.
Mauro
2015-01-19 9:34 GMT+01:00 Jody Garnett <jody.garnett@anonymised.com>:
On Mon, Jan 19, 2015 at 12:30 AM Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com> wrote:
Should I do it?Mauro
Jody
@mauro_bart
Jody Garnett
Hi Jody,
Mauro
- ant wfs-1.1-log
- grep Failed
- RETURN=1
- echo RETURN=1
RETURN=1
Changes
origin/master
Summary
Jody Garnett
@mauro_bart
@mauro_bart
