[Geoserver-devel] Another issue with the repo moving
trying to build geofence I get the following:
[WARNING] The POM for org.opengeo:geodb:jar:0.6 is missing, no dependency information available
Downloading: http://mirrors.ibiblio.org/maven2/org/opengeo/geodb/0.6/geodb-0.6.jar
I added the boundless repo, but version 0.6 is not there.
This dependency is apparently required by hibernate spatial:
hibernate-spatial-h2-geodb, version 1.1.1
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Should be there now.
On Fri, Oct 3, 2014 at 11:13 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Justin Deoliveira
VP Engineering | Boundless
jdeolive@anonymised.com
@boundlessgeo
On Fri, Oct 3, 2014 at 9:26 PM, Justin Deoliveira <jdeolive@anonymised.com
Confirmed working, thank you for the fast action :slight_smile:
Ing. Andrea Aime
@geowolf
Technical Lead
