[Geoserver-devel] Another possible refactor: avoid K&R variable declaration style
continuing on the thread of possible code improvements, I’d proposed to move variable declarations
as close to their usage as possible.
There is currently a lot of code, probably written by people coming from C K&R experiences, that
declares variables close to the top of a method, and then assigns them way later. Or even just code
that splits declaration and assignment over two subsequent lines.
Personally, both annoy me. The first one looks nothing like Java code, and makes it harder to figure
out what is the type of the assigned variable. The second looks unnecessarily verbose.
IntelliJ provides an “assignment can be joined with declaration” refactor which seems to do the trick.
I’ve experimented running it, here are draft PRs showing the results:
PS: IntelliJ offers another K&R avoidance refactor, dealing with array declaration, switching all
“Object myArray” to “Object myArray”. I think it’s also worth applying, as odd and out of place
the C style approach might seem, there are actually hundreds of those in the code base (470 to be precise)
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
