looking into an issue with GetFeatureInfo not returning any feature
on a map that clearly had some (http://jira.codehaus.org/browse/GEOS-4252)
I discovered an hidden "easter egg" in the code: if a WMS request misses
the _required_ parameter SRS GetMap blindly assumes EPSG:4326 whilst
GetFeatureInfo simply starts going bonkers.
Now, the parameter is _required_, so I would just go and throw an exception
there (and btw, surprised CITE tests do not check for that... checked, there
is no "cite compliance" trick in the wms code).
If we really really want to be lenient and keep on accepting malformed requests,
we should then try to use the first layer srs, not just pick a random
srs that may have
nothing to do with the data in the current request.
However that makes for quite a hard to debug issues: it took step by step code
debugging to find out why GetFeatureInfo was not even reaching to the database
when clicking, in the preview, on a map that clearly had features showing (at
that scale, GFI without the SRS was computing the wrong scale and deciding
all the scale dependent rules were inactive).
That's why I'm more of leaning towards simply throwing an exception.
Opinions?
Ing. Andrea Aime
Senior Software Engineer
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
On my opinion we should just throw an exception since the parameter is required.
Ing. Alessio Fabiani
Founder / CTO GeoSolutions S.A.S.
phone: (+39) 0584 96.23.13
fax: (+39) 0584 96.23.13
mobile:(+39) 349 82.27.000
On Fri, Dec 10, 2010 at 10:04 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
I discovered an hidden “easter egg” in the code: if a WMS request misses
the required parameter SRS GetMap blindly assumes EPSG:4326 whilst
Now, the parameter is required, so I would just go and throw an exception
there (and btw, surprised CITE tests do not check for that… checked, there
is no “cite compliance” trick in the wms code).
srs that may have
That’s why I’m more of leaning towards simply throwing an exception.
Opinions?
Ing. Andrea Aime
fax: +39 0584962313
Geoserver-devel mailing list
I'd say throw an exception. For lenient there's the reflector.
required.
http://www.linkedin.com/in/alessiofabiani
http://twitter.com/simogeo
feature
request misses
whilst
an exception
checked, there
malformed requests,
random
srs that may have
step by step code
to the database
and deciding
exception.
Opinions?
Ing. Andrea Aime
fax: +39 0584962313
Gabriel Roldan
groldan@anonymised.com
Expert service straight from the developers
