On Mon, Oct 31, 2016 at 7:14 AM, Jody Garnett <jody.garnett@anonymised.com>
wrote:
Yes there is interest - it would offer a "bridge" to organizations that
are shutting down ArcSDE (and enable them to continue to use GeoServer).
Frankly it may scale better than ArcSDE...
This is interesting... care to elaborate?
When we did the benchmarking sessions back at FOSS4G 2010 we noticed SDE
was not adding any measurable
overhead compared to direct access to the same spatial DB (at all tested
load levels), and we were actually
surprised.
I sort of doubt a JSON based transport protocol could be competitive with
that performance wise, but happy
to be proved wrong of course
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
