[Geoserver-devel] Any hope to get Hudson CITE 1.1 build back in shape?
the current CITE 1.1 status makes it a bit harder to know if we are
really compliant,
and also harder to know if we're in a state that can be released...
the failures may
be actual, but we don't get to know.
Any hope to get it running properly again?
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
I knew this email was going to be coming soon :slight_smile: Apologies for putting it off.
At this point I am sort of at a loss… my next course of action is to try running the tests from a different server to see if it does any better. I will try to slot that in now. Keep your fingers crossed.
On Fri, Aug 12, 2011 at 4:36 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
really compliant,
and also harder to know if we’re in a state that can be released…
the failures may
be actual, but we don’t get to know.
Ing. Andrea Aime
Tech lead
Get a FREE DOWNLOAD! and learn more about uberSVN rich system,
user administration capabilities and model configuration. Take
the hassle out of deploying and managing Subversion and the
tools developers use with it.
http://p.sf.net/sfu/wandisco-dev2dev
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Ok, the failures due to network issues should be solved now. I copied the xml.xsd file from www.w3.org to the local webserver and set up a hosts entry to point at it and all good.
The remaining failures for wfs-1.1-trunk and wms-1.3-trunk appear to be legitimate as I was able to reproduce them locally. Will try to look into those later.
-Justin
On Fri, Aug 12, 2011 at 7:47 AM, Justin Deoliveira <jdeolive@anonymised.com.1501…> wrote:
really compliant,
the failures may
Ing. Andrea Aime
Tech lead
Justin Deoliveira
Justin Deoliveira
