This PR is adding the ability to use GeoFence’s IP address range to users of the GeoServer internal GeoFence. It is part enhancement and part bug fix - so does anyone have an objection to me back porting it to 2.18.x before the usual month is up?
The PR is at https://github.com/geoserver/geoserver/pull/4555
Ian
Ian Turton
+0
We have been testing this already quite a bit even before it landed on master
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
