[Geoserver-devel] Anyone runs trunk these days?
I was trying to run geoserver trunk after a while but jetty:run is giving me
the following startup error, any clue will be appreciated:
org.springframework.beans.FatalBeanException: Could not instantiate class
[org.geoserver.rest.WrappingController]; constructor threw exception; nested
exception is java.lang.Error: Unresolved compilation problems:
        The import org.restlet cannot be resolved
        The import com.noelios cannot be resolved
Gabriel
Interesting. David also reported problems with running with jetty:run today. However I just tried and it started up like a charm. The only issues that I am aware of are it not running on java 1.4.
It seems that you are picking up the restlet stuff... did you build with -Dcommunity? I think that profile adds the rest config stuff to the web modules dependencies.
Gabriel Roldán wrote:
I was trying to run geoserver trunk after a while but jetty:run is giving me the following startup error, any clue will be appreciated:
org.springframework.beans.FatalBeanException: Could not instantiate class [org.geoserver.rest.WrappingController]; constructor threw exception; nested exception is java.lang.Error: Unresolved compilation problems:
Gabriel
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-devel mailing list
!DSPAM:4007,47d875f3188131336712104!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
The RESTlet wrapping controller lives in the main module these days, it should
be picked up regardless of whether you use -Dcommunity or not (as far as I
know). My issue with jetty:run is entirely different from this (maven is
pulling in both jetty 6.1.5 and 6.1.8 jars, causing compilation issues in
web/test). I'll check out a clean copy of trunk and see if I can
replicate/resolve this issue.
-David
> Hi,
> Gabriel
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
I can't replicate either issue here.
-David
should be picked up regardless of whether you use -Dcommunity or not (as
far as I know). My issue with jetty:run is entirely different from this
(maven is pulling in both jetty 6.1.5 and 6.1.8 jars, causing compilation
issues in web/test). I'll check out a clean copy of trunk and see if I can
-David
> > Hi,
> > problems: The import org.restlet cannot be resolved
> > Gabriel
> >-- This SF.net email is sponsored by: Microsoft
> > _______________________________________________
!DSPAM:4040,47d932e867935332866982!
Doh, I tried both with and without -Dcommunity, using clear always and with
different JVM's...
gonna investigate further later though, thanks for the info.
Gabriel
-David
> can replicate/resolve this issue.
> -David
> > > Hi,
> > > compilation problems: The import org.restlet cannot be resolved
> > > Gabriel
> > >-- -- This SF.net email is sponsored by: Microsoft
!DSPAM:4045,47d94d0c114434901796417!
