[Geoserver-devel] Apollo slave 1 bounced
Jenkins was hung up on the unknown task again this morning so I disconnected and reconnected slave-1 and it seems happier, but I never seem to see more than one job running, is that right?
Ian
Ian Turton
Pretty much, most projects are linked by snapshots and we cannot replace them while another job
running uses them.
So GeoTools/GeoServer/GeoWebCache are in the same build group, and only one of them runs
at the same time.
The CITE tests could be running in parallel though… but we should check they are not opening a port on 8080,
otherwise some half-online tests in GeoServer would fail…
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
The only jobs that can really run in parallel with other jobs are the doc builds; everything else is pretty strictly locked into workspaces so as to not cause maven conflicts (or port conflicts). (There are a couple other exceptions for some of the plugin-specific test builds)
If I remember correctly, the cite tests run a geoserver binary on 8080, so that will probably cause issues.
Torben
On Mon, Sep 24, 2018 at 1:38 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
running uses them.
at the same time.
Geoserver-devel mailing list
