Hej
We have currently three business cases which requires various levels of
Planar 2D Polygon Topology.
When time and weather permits (I have vacation), I will describe these
in a document and send to you.
Can you point me to relevant docmentation about the INSPIRE Hydrographic
and Transport data models?
Is INSPIRE Hydrographic using the S57 (and/or the coming S100) standard?
S57 has an advanced, non-redundant topology data structure and object
model with many-many relationships between spatial and feature objects.
As I have worked with S57 for several years (developed ESRI-based
systems), I may give some assistance.
Best regards
Andreas
-----Original Message-----
From: Rob Atkinson [mailto:robatkinson101@anonymised.com]
Sent: den 17 juli 2009 09:03
To: Oxenstierna Andreas
Cc: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] App-schema and GML topology
I'm currently looking at doing some work with Justin in extending the
bindings to support schema-driven complex attributes as well as
source-data driven 2D geometry -objects, mainly in order to handle 3D
and 1D geometry and temporal data types. The approach should be fairly
generic though, and I'm interested in supporting topology operations in
queries (e.g. to support the INSPIRE Hydrographic and Transport data
models) - though this will be next year in current project priorities.
Please provide some simple sample data, application schema and queries
for your requirements and I'll have a look to see how achievable it is
as part of the process.
Regards
Rob Atkinson
On Fri, Jul 17, 2009 at 1:06 AM, Oxenstierna
Andreas<Andreas.Oxenstierna@anonymised.com> wrote:
Hej
Can the app-schema extension handle GML3 2D topology structures, like
Planar Topology, as defined in GML3 spec chapter 13 (and ISO19107) ?
If so, how may GeoServer communicate (read/write) the topology
information with a topology-aware client?
Best regards
Andreas Oxenstierna
-------- Enter the BlackBerry Developer Challenge This is your chance
to win up to $100,000 in prizes! For a limited time, vendors
submitting new applications to BlackBerry App World(TM) will have the
opportunity to enter the BlackBerry Developer Challenge. See full
prize details at: http://p.sf.net/sfu/Challenge
Geoserver-devel mailing list
