[Geoserver-devel] App-schema joining docs clarification
the documentation states that app-schema jonining support is on by default,
but also that if not all the conditions for joining are met, then runtime exceptions
will be thrown.
Is that actually the case? Or the joining is silently disabled if the conditions for
sql joins are not met?
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
forgot to add a reference to the doc page, here:
http://docs.geoserver.org/latest/en/user/data/app-schema/joining.html
On Fri, May 6, 2016 at 1:05 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
will be thrown.
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Andrea,
judging from the code in MappingFeatureIteratorFactory:
https://github.com/geotools/geotools/blob/42c4cc0c3d850b1dea50c07108f171aace35a798/modules/extension/app-schema/app-schema/src/main/java/org/geotools/data/complex/MappingFeatureIteratorFactory.java#L119
it seems that if the conditions for joining are not met, it is silently disabled; runtime exceptions are thrown only if the conditions are not met AND the user has explicitly enabled joining support setting -Dapp-schema.joining=true on the command line.
On Fri, May 6, 2016 at 1:06 PM, Andrea Aime <andrea.aime@anonymised.com.1268…> wrote:
Find and fix application performance issues faster with Applications Manager
Applications Manager provides deep performance insights into multiple tiers of
your business applications. It resolves application problems quickly and
reduces your MTTR. Get your free trial!
https://ad.doubleclick.net/ddm/clk/302982198;130105516;z
Geoserver-devel mailing list
will be thrown.
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Best regards,
Stefano Costa
[http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Dott. Stefano Costa
Senior Software Engineer
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility  for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Fri, May 6, 2016 at 1:26 PM, Stefano Costa <
stefano.costa@anonymised.com> wrote:
Hi Andrea,
That's good I guess, but the docs need amending... there is a third
undocumented behavior for when the param is not explicitly set
Ing. Andrea Aime
@geowolf
Technical Lead
I do not think there is a test for the CQL conditions being met. Joining is automatically disabled for non-JDBC stores.
Niels, anything to add?
Kind regards,
Ben.
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Sounds right, but it was Rini I believe who turned on joining by default for jdbc stores rather than needing to be specified explicitly.
Kind Regards
Niels
Kind regards,
Ben.
