Dear all,
I’m working on automating the creation/update of app-schema datastores in GeoServer leveraging the REST API.
The current API already allows the creation of an app-schema datastore and, of course, it is already possible to create secondary namespaces/workspaces via REST: what is missing (at least AFAIK) is the possibility to upload an app-schema mapping file to an already created app-schema datastore (also creating a new one based on the uploaded mapping file would be nice).
I had a quick look at the REST endpoints we already have and I focused on this one:
/workspaces//datastores//[file|url|external][.extension]
which is ultimately handled by either DataStoreFileResource or CoverageStoreFileResource. The supported extensions so far are shape, properties, h2 and spatialite.
I’m proposing to add a new extension, appschema, that will be handled by a new kind of resource, let’s call it AppSchemaDataAccessResource, extending StoreFileResource, which will take care of copying the uploaded mapping file to its proper location.
I’m a bit puzzled as to where (i.e. in which module) this new class should be put: I guess gs-restconfig would be the wrong place, since it would make it dependent on gt-app-schema. Perhaps the best way would be to create a new module, let’s call it gt-app-schema-rest, containing just AppSchemaDataAccessResource and occasional supporting classes, and then have StoreFileFinder (gs-restconfig module) somehow look it up dynamically.
Any thoughts/suggestions?
Thanks!
Best regards,
Stefano Costa
Dott. Stefano Costa
Senior Software Engineer
Via Poggio alle Viti 1187
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
