[Geoserver-devel] App-schema: mapping GeometryArrayPropertyType
still looking into app schema here. Today I noticed that the schema I
have to map to uses a
GeometryArrayPropertyType. As far as I can see there is no support for it.
A GeometryArrayPropertyType is not a GML geometry (like
GeometryCollection), and it's not
a multi valued property either, it's a plain jane container of
heterogeneous geometries instead:
<mygeomarray>
  <Point>...</Point>
  <Polygon>...<Polygon>
</mygeomarray>
Now... how the heck to I map to this? I guess there are two questions
to be answered:
- what in memory representation to give the array
- how to make the encoder turn it into an array
Plan A:
- assume the geometries are all in the same SRS
- represent the thing as a GeometryCollection
- roll out a binding for GeometryPropertyType that can take a
GeometryCollection and encode it
Plan A.1:
- as above, but create a converter from GeometryCollection to
Geometry. Wondering if the
  encoder at this point will know what to do, or if I still have to
create a (simpler) binding
Plan B:
- represent the attribute as a Geometry directly
- modify app-schema to handle that case as well?
- create a binding to encode the thing.
I'm leaning towards A.1 but would like to hear what others think about
this case.
Ing. Andrea Aime
Senior Software Engineer
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
