[Geoserver-devel] App-Schema mappings default geometry
Currently is not possible to specify in App-Schema mappings the default geometry of a mapped feature type,
note that having a default geometry defined is mainly important for WMS.
Most of the times a geometry will be available in the root feature type and a default geometry will be correctly
and automatically selected.
But in certain situations a feature type may have multiple geometries, or the geometry may be nested,
for example:
<wfs:member>
  <st:Station gml:id​ = "station.st.1"​>
    <st:name>​station1​</st:name>
    <st:location>
      <st:name>​Europe​</st:name>
      **<st:position>**
**        <gml:Point srsDimension​="2"**
**          srsName​=["http://www.opengis.net/gml/srs/epsg.xml#4326"](http://www.opengis.net/gml/srs/epsg.xml#4326)​ >**
**          <gml:pos>​-1.0 1.0​</gml:pos>**
**        </gml:Point>**
**      </st:position>**
    </st:location>
  </st:Station>
</wfs:member>
In this case the geometry is nested inside the location element. I propose to extend App-Schema
mappings to allows us to define explicitly the default geometry:
<FeatureTypeMapping>
  <sourceDataStore>​stations​</sourceDataStore>
  <sourceType>​stations​</sourceType>
  <targetElement>​st:Station​</targetElement>
  **<defaultGeometry>st:location/st:position</defaultGeometry>**
  <attributeMappings>
    <AttributeMapping>
      <targetAttribute>​st:Station​</targetAttribute>
      <idExpression>
        <OCQL>​strConcat('station.', ID)​</OCQL>
      </idExpression>
    </AttributeMapping>
Any objection or comments ?
Nuno Oliveira
Nuno Oliveira
GeoServer Professional Services from the experts! Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
55054  Massarosa (LU)
fax:      +39 0584 1660272
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
Nuno,
that sounds like a useful improvement. One consideration is what happens when a nested geometry is multivalued and has a cardinality of zero or more than one. Also, do you anticipate that your implementation will work with nested properties generated by feature chaining? I am thinking of joining and filtering with spatial predicates.
Please also update <modules/extension/app-schema/app-schema/src/test/resources/test-data/AppSchemaDataAccess.xsd> to include this new element. I think this is still the canonical source for the schema, although we do not yet have a good way of distributing it.
Kind regards,
Ben.
On 19/02/18 22:29, Nuno Oliveira wrote:
for example:
&lt;wfs:member&gt;
   &lt;st:Station gml:id​ = &quot;station\.st\.1&quot;​&gt;
     &lt;st:name&gt;​station1​&lt;/st:name&gt;
     &lt;st:location&gt;
       &lt;st:name&gt;​Europe​&lt;/st:name&gt;
\*&lt;st:position&gt;\*
\*         &lt;gml:Point srsDimension​=&quot;2&quot;\*
\*           srsName​=&quot;http://www.opengis.net/gml/srs/epsg.xml#4326&quot;​ &gt;\*
\*           &lt;gml:pos&gt;​\-1\.0 1\.0​&lt;/gml:pos&gt;\*
\*         &lt;/gml:Point&gt;\*
\*       &lt;/st:position&gt;\*
     &lt;/st:location&gt;
   &lt;/st:Station&gt;
&lt;/wfs:member&gt;
&lt;FeatureTypeMapping&gt;
   &lt;sourceDataStore&gt;​stations​&lt;/sourceDataStore&gt;
   &lt;sourceType&gt;​stations​&lt;/sourceType&gt;
   &lt;targetElement&gt;​st:Station​&lt;/targetElement&gt;
\*&lt;defaultGeometry&gt;st:location/st:position&lt;/defaultGeometry&gt;\*
   &lt;attributeMappings&gt;
     &lt;AttributeMapping&gt;
       &lt;targetAttribute&gt;​st:Station​&lt;/targetAttribute&gt;
       &lt;idExpression&gt;
         &lt;OCQL&gt;​strConcat\(&#39;station\.&#39;, ID\)​&lt;/OCQL&gt;
       &lt;/idExpression&gt;
     &lt;/AttributeMapping&gt;
Nuno Oliveira
Check out the vibrant tech community on one of the world's most
Geoserver-devel mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <https://transient.nz/&gt;
New Zealand
Hi Ben,
Thank you for the feedback :slight_smile:
In the first step nested properties generated by feature chaining will be ignored, the default geometry will need to be a mapped property of the feature type.
Then, this may be extended to support the use case of having a chained feature with cardinality 0 or 1.
Thank you for the heads up regarding the AppSchemaDataAcess schema, I will update it.
Nuno Oliveira
On 02/19/2018 10:42 PM, Ben Caradoc-Davies wrote:
Nuno,
Kind regards,
Ben.
for example:
&lt;wfs:member&gt;
     &lt;st:location&gt;
   &lt;/st:Station&gt;
&lt;/wfs:member&gt;
Nuno Oliveira
Nuno Oliveira
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
@nmcoliveira
Software Engineer
