which are the 2 methods which set the 2 values, both count and total=0, i cant find an other place where the code could set those values in the response, and my response is numberMatched=“unknown” numberReturned=“4”
Just a bit lost with this if someone could give advices thanks
response, and my response is numberMatched="unknown" numberReturned="4"
Counting in app-schema is so expensive that it's not even done for the ones
returned, there is a XSLT sheet counting the results after they are
encoded to GML.
I believe the reason is that the code can't get to know how many records are
matched without fully reading them anyways.
Thanks for repply.
Does it also mean that other operation like sorting cannot work cause it’s too expensive ?
Actually, i use WFS 2.0.0 on master branch many WFS services don’t work pretty well, i wonder if it is cause the master is a bit broken, or just because it is app-schema that can’t support some of theses services:
sortBy doesnt work (is it because it’s too expensive or is it a bug ? )
startIndex doesnt work (it starts with the same feature whatever startindex value is, and the next=“” param in the response is not set)
resultType doesnt work either …
etc…
Do you think it is normal behavior or bug that i have to investigate on ?
Counting in app-schema is so expensive that it’s not even done for the ones
encoded to GML.
I believe the reason is that the code can’t get to know how many records are
response, and my response is numberMatched="unknown"numberReturned="4"
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
Software Engineer
Software Engineer
LogMeIn Central: Instant, anywhere, Remote PC access and management.
Stay in control, update software, and manage PCs from one command center
Diagnose problems and improve visibility into emerging IT issues
Automate, monitor and manage. Do more in less time with Central http://p.sf.net/sfu/logmein12331_d2d
Geoserver-devel mailing list
Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
