[Geoserver-devel] App-schema test failure with oracle
Hi Ben & Jody,
I recently are trying to fix the Jenkins geoserver app-shcema online testing failure. (http://ares.opengeo.org/jenkins/view/geoserver/job/geoserver-master-app-schema-online/)
After I reproduced the problem at my developing machine , I found the issue may come org.geoserver.test.onlineTest.setup.AppSchemaTestOracleSetup.createTables. and it looks because the spatialIndex was not cleared after being used , and it then keep being added to the query.
after I added one line code to clear the spatialIndex in the loop, the Jenkins job works fine now.
Can someone review the code and confirm that this is a right fix.
Lingbo Jiang
Software Engineer
DP&S CSIRO
Cnr Vimiera & Pembroke Roads
MARSFIELD NSW 2122
Ph:+61-2-9372 4696
www.csiro.au/
private void createTables(Map<String, File> propertyFiles, String parser)
            throws IllegalAttributeException, NoSuchElementException, IOException {
        StringBuffer buf = new StringBuffer();
        StringBuffer spatialIndex = new StringBuffer();
        // drop table procedure I copied from Victor's Oracle_Data_ref_set.sql
        buf
                .append("CREATE OR REPLACE PROCEDURE DROP_TABLE_OR_VIEW(TabName in Varchar2) IS ")
                .append("temp number:=0;")
                .append(" tes VARCHAR2 (200) := TabName;")
                .append(" drp_stmt VARCHAR2 (200):=null;")
                .append("BEGIN select count(*) into temp from user_tables where TABLE_NAME = tes;")
                .append("if temp = 1 then drp_stmt := 'Drop Table '||tes;")
                .append("EXECUTE IMMEDIATE drp_stmt;")
                 // drop views too
                .append("else select count(*) into temp from user_views where VIEW_NAME = tes;")
                .append("if temp = 1 then drp_stmt := 'Drop VIEW '||tes;")
                .append("EXECUTE IMMEDIATE drp_stmt;end if;end if;")
                .append("EXCEPTION WHEN OTHERS THEN ")
                .append(
                        "raise_application_error(-20001,'An error was encountered - '||SQLCODE||' -ERROR- '||SQLERRM);")
                .append("END DROP_TABLE_OR_VIEW;\n");
        for (String fileName : propertyFiles.keySet()) {
                       ............Skip many line code............
                       id = feature.getIdentifier();
                    // insert primary key
                    values[valueIndex] = "'" + id.toString() + "'";
                    buf.append(StringUtils.join(values, ","));
                    buf.append(")\n");
            buf.append(spatialIndex.toString());
            spatialIndex.delete(0, spatialIndex.length()); /////// Since spatialIndex did not cleared , it will be added in next loop.
            if (buf.length() > 0) {
                this.sql = buf.toString();
I created a jira task for this issue (https://osgeo-org.atlassian.net/browse/GEOS-7069).
And pullrequest as well (https://github.com/geoserver/geoserver/pull/1102/files).
Lingbo Jiang
Software Engineer
DP&S CSIRO
MARSFIELD NSW 2122
Ph:+61-2-9372 4696
www.csiro.au/
________________________________________
From: Lingbo.Jiang@anonymised.com [Lingbo.Jiang@anonymised.com]
Sent: Thursday, June 11, 2015 11:16 AM
To: jody.garnett@anonymised.com; ben@anonymised.com
Cc: geoserver-devel@lists.sourceforge.net
Subject: [ExternalEmail] [Geoserver-devel] App-schema test failure with oracle
Hi Ben & Jody,
Lingbo Jiang
Software Engineer
DP&S CSIRO
MARSFIELD NSW 2122
Ph:+61-2-9372 4696
www.csiro.au/
        buf
                 // drop views too
                .append(
                    buf.append(")\n");
Geoserver-devel mailing list
Jody,
FYI this looks good and has been merged by Victor. See the pull request for discussion.
Kind regards,
Ben.
Lingbo Jiang
Software Engineer
DP&S CSIRO
MARSFIELD NSW 2122
Ph:+61-2-9372 4696
www.csiro.au/
Hi Ben & Jody,
Lingbo Jiang
Software Engineer
DP&S CSIRO
MARSFIELD NSW 2122
Ph:+61-2-9372 4696
www.csiro.au/
         buf
                  // drop views too
                 .append(
                     buf.append(")\n");
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
