I do have a test that keeps on failing locally on my machine:
Tests run: 27, Failures: 1, Errors: 0, Skipped: 2, Time elapsed: 12.52 sec <<< FAILURE!
testDescribeFeatureTypeNoTypes(org.geoserver.test.FeatureChainingWfsTest) Time elapsed: 15 sec <<< FAILURE!
java.lang.AssertionError: expected:<2> but was:<3>
at org.junit.Assert.fail(Assert.java:88)
at org.junit.Assert.failNotEquals(Assert.java:743)
at org.junit.Assert.assertEquals(Assert.java:118)
at org.junit.Assert.assertEquals(Assert.java:555)
at org.junit.Assert.assertEquals(Assert.java:542)
at org.geoserver.test.FeatureChainingWfsTest.testDescribeFeatureTypeNoTypes(FeatureChainingWfsTest.java:325)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
At first I thought “hey, my geotools checkout is not up to date”, and indeed I was missing some commits,
then I’ve tried getting jars from the boundless repo instead, but the outcome does not change.
I’ve run the test in Eclipse, and fails the same way.
Checking the windows and openjdk build servers, they also failing the same way:
http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/lastCompletedBuild/testReport/
http://build.geo-solutions.it/jenkins/job/GeoServer-Master-OpenJDK8/1185/consoleFull
Anyone has a clue as to what might be causing this?
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
