[Geoserver-devel] app-schema WMS test changes
Rini and Niels,
current app-schema WMS tests use JPEG output, so perceptualdiff is heavily affected by changes in JPEG compression artifacts. To fix a build failure in app-schema online tests (rendering the stratchart), I have manually reviewed and updated the WMS responses and changed them all to PNG. As PNG is lossless, this should remove the influence of compression artifacts.
I am running a final full test and will commit to master if successful. Please let me know if you have objections!
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
I have no objections. Thanks for fixing the failure.
Rini
________________________________________
Sent: Monday, 13 January 2014 4:16 PM
To: Angreani, Rini (CESRE, Kensington); Niels Charlier
Cc: geoserver-devel@lists.sourceforge.net
Subject: app-schema WMS test changes
Rini and Niels,
Kind regards,
Software Engineer
On Mon, Jan 13, 2014 at 9:16 AM, Ben Caradoc-Davies <
Ben.Caradoc-Davies@anonymised.com> wrote:
Rini and Niels,
Yep, I believe this kind of change was done on other tests already for the
same reason
== Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On 13/01/14 09:16, Ben Caradoc-Davies wrote:
Rini and Niels,
Kind regards,
Sounds Good
Niels
