lately I have seen some unrelated appveyor failures on GS PRs, a few examples:
The build failures seem to vary, although they are always related with tests,.
Restarting the build will make appveyor fail again but on a different test, I have see failures on GWC, REST-CONFIG, CORE …
Anyone experiencing the same?
Thank you,
Nuno Oliveira
Nuno Oliveira
GeoServer Professional Services from the
experts!
Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
Con riferimento alla normativa sul trattamento dei dati
personali (Reg. UE 2016/679 - Regolamento generale sulla
protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto,
gli eventuali allegati, etc.) è un dato la cui conoscenza
è riservata al/i solo/i destinatario/i indicati dallo
scrivente. Se il messaggio Le è giunto per errore, è
tenuta/o a cancellarlo, ogni altra operazione è illecita.
Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to
which it is addressed and may contain information that
is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European
Regulation 2016/679 “GDPR” - copying, dissemination or
use of this e-mail or the information herein by anyone
other than the intended recipient is prohibited. If you
have received this email by mistake, please notify
us immediately by telephone or e-mail.
Hi Nuno,
I’ve spent a few hours Sunday tracking down and hopefully fixing the rest config one, you can rebase PRs to the latest master to get that fix. Not sure about the others, but the recipe is the same, get a dev env going on Windows, reproduce, look for file path and contention issues (most of the time) and hope the fix does not end up breaking Linux
Il lun 4 nov 2019, 12:52 Nuno Oliveira <nuno.oliveira@anonymised.com8…> ha scritto:
Thank you,
Nuno Oliveira
Nuno Oliveira
experts!
Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
@nmcoliveira
Software Engineer
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
Geoserver-devel mailing list
Hi Andrea,
great thank you for the feedback and work on this.
Nuno Oliveira
On Mon, 2019-11-04 at 16:47 -0500, Andrea Aime wrote:
Hi Nuno,
Il lun 4 nov 2019, 12:52 Nuno Oliveira <nuno.oliveira@anonymised.com> ha scritto:
Thank you,
Nuno Oliveira
Nuno Oliveira
experts!
@nmcoliveira
Software Engineer
Nuno Oliveira
experts!
@nmcoliveira
Software Engineer
