Ciao Greg,
I have talked to daniele, and right now he is pretty much stuffed (as
I am ), therefore the best option, if you have some hours to spend
on this now, if you could try to extend imageio-ext to support arcinfo
binary through gdal. Since gdal supports this format by default it
should be as easy as creating 2 or 3 classes for SPIs in imageioext as
well as in the geotools imageio-ext-gdal, and you should be able to
use arcinfo binary in geoserver 1.7 right away. Of course we can guide
you through the process.
Simone.
On Wed, Oct 1, 2008 at 10:53 PM, Greg Ederer <greg@anonymised.com> wrote:
Hi Daniele,
Thanks for getting back to me. I spoke with my boss, and it looks like I
can get some time to work on this in December. It might make a nice
Christmas present In the mean time, I'll take a look at ImageIO-Ext.
Greg
Daniele Romagnoli wrote:
Hi Greg,
actually I'm busy with some deadlines of funded projects.
Anyway, to support Binary Arc/Info we need to define and implement a new
ImageIO plugin (via our ImageIO-Ext GDAL framework) as well as a new
Geotools plugin. After this we need to integrate them on Geoserver. This
would require some days of work.
Waiting for your opinions,
regards.
Daniele
On Wed, Oct 1, 2008 at 7:53 PM, Simone Giannecchini <simboss1@anonymised.com>
wrote:
Ciao Greg,
GeoTools and therefore GeoServer does not support this format as of now.
As you noticed, it is supported by GDAL, which means we can support it
inside geotools/geoserver quite easily through the imageio-ext [1]
project and its geotools/geoserver counterpart [2][3].
We have not added support for it so far becasue of lack of interest,
but it seems that things have changed :-).
I am ccing daniele so that he willprovide more details on this.
Simone.
[1] https://imageio-ext.dev.java.net/
[2] imageio-ext
[3] http://geoserver.org/display/GEOSDOC/ImageIO-ext+GDAL+extensions
On Wed, Oct 1, 2008 at 7:23 PM, Greg Ederer <greg@anonymised.com> wrote:
> Hi Justin,
> Thanks for the response. It looks like GDAL has some support for
> reading these files. Not sure about GeoTools. I'll do some more
> looking into this today. In any case, a lot of work has been done on
> reverse engineering the (proprietary) file spec, so a native Java
> implementation might be possible. I'd have to scope it out, and run it
> by my boss.
> It would be great to know whether anyone has tried to do this before.
> If I'm heading for a giant brick wall, I might want to put on a helmet
> Cheers,
> Greg
> Justin Deoliveira wrote:
>> Hi Greg,
>> As far as i know (and please coverage folks correct me if i am wrong)
>> you are correct, only ascii grids are handled. I think it would be
>> great if you could contribute and help develop a format for binary
>> grids.
>> Simone and the coverage exprts should be able to better guide you on
>> how to proceed.
>> -Justin
>> Greg Ederer wrote:
>>> Hi,
>>> We have a large amount of data in Arc/Info binary grid format. I an
>>> ESRI newbie. But, I understand that there are two Arc/Info grid
>>> formats: ASCII and binary. It looks to me like GeoServer only serves
>>> the ASCII format out of the box. Is this correct? If so, is there a
>>> GeoServer plugin that enables serving of these binary grids?
>>> If not, my employer might be willing to pay me to work on this.
>>> Cheers,
>>> Greg
> | E R G O N O S I S
> | Greg Ederer
> | Lead Developer
> | greg@anonymised.com
> | 360.774.6848
> This SF.Net email is sponsored by the Moblin Your Move Developer's
> challenge
> Build the coolest Linux based applications with Moblin SDK & win great
> prizes
> Grand prize is a trip for two to an Open Source event anywhere in the
> world
> http://moblin-contest.org/redirect.php?banner_id=100&url=/
> Geoserver-devel mailing list
> Geoserver-devel@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Eng. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://www.geo-solutions.it/simone.giannecchini
http://www.linkedin.com/in/simonegiannecchini
challenge
prizes
world
Eng. Daniele Romagnoli
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
mob: +39 328 0559267
| E R G O N O S I S
| Greg Ederer
| Lead Developer
| greg@anonymised.com
| 360.774.6848
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
