[Geoserver-devel] artifactory / ares / jenkins chat
And we are back to square one:
<?xml version="1.0" encoding="UTF-8"?> org.geotools gt-render 14-SNAPSHOT 20151006.130203 251 20160216183323 sources jar 14-20151006.130203-251 20151006130203 jar 14-20151006.130203-251 20151006130203 tests jar 14-20151006.130203-251 20151006130203 pom 14-20151006.130203-251 20151006130203
https://repo.boundlessgeo.com/main/org/geotools/gt-render/14-SNAPSHOT/maven-metadata.xml
We should really get rid of all the 2015 jars from the repo, maybe that will make it go away.
If not, we’ll have proof that something is indeed deploying those jars…
On Tue, Feb 16, 2016 at 7:34 PM, Jody Garnett <jgarnett@anonymised.com> wrote:
We have success - here is the result after a 14-SNAPSHOT build on ares:
https://repo.boundlessgeo.com/snapshot/org/geotools/xsd/gt-xsd-sld/maven-metadata.xml
And the contents:
<?xml version="1.0" encoding="UTF-8"?> org.geotools.xsd gt-xsd-sld 14-SNAPSHOT 20160216.183314 1 20160216183316 sources jar 14-20160216.183314-1 20160216183314 jar 14-20160216.183314-1 20160216183314 pom 14-20160216.183314-1 20160216183314
Build number 1 is amusing, but there you go…
On Tue, Feb 16, 2016 at 10:19 AM, Jody Garnett <jgarnett@anonymised.com> wrote:
Here is chat from zoom:
From Chris to Everyone: (09:01 AM)
Interesting, from a geotools 14.x build: Downloaded: https://repo.boundlessgeo.com/snapshot/org/geotools/geotools/maven-metadata.xml (427 B at 2.9 KB/sec) Uploading: https://repo.boundlessgeo.com/snapshot/org/geotools/geotools/14-SNAPSHOT/maven-metadata.xml 593/593 B Looks like it’s maven itself to re-upload a modified metadata.xml… and it’s a bit old: /opt/apache-maven-3.0.4/bin/mvn -f modules/pom.xml javadoc:aggregate
From Me to Everyone: (09:03 AM)
https://osgeo-org.atlassian.net/browse/GEOS-7329
https://osgeo-org.atlassian.net/browse/GEOT-5358
From Andrea Aime to Everyone: (09:09 AM)
http://ares.boundlessgeo.com/jenkins/view/geotools/job/geotools-14.x/92/consoleText
-U deploy -Djava.awt.headless=true -DskipTests -Dall
mvn -U deploy -Djava.awt.headless=true -DskipTests -Dall
From Andrea Aime to Everyone: (09:14 AM)
https://github.com/geotools/geotools/blob/14.x/pom.xml
From Aaron Rhodes to Everyone: (09:55 AM)
POST /api/maven/calculateMetadata/libs-release-local/org/acme
Jody Garnett
Community Lead | Boundless
@jodygarnett
http://boundlessgeo.com/
Jody Garnett
@jodygarnett
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi Andrea,
Same for 15-SNAPSHOT.
https://repo.boundlessgeo.com/main/org/geotools/gt-render/15-SNAPSHOT/maven-metadata.xml
<?xml version="1.0" encoding="UTF-8"?> org.geotools gt-render 15-SNAPSHOT 20151006.095547 25 20160218071809 sources jar 15-20151006.095547-25 20151006095547 jar 15-20151006.095547-25 20151006095547 tests jar 15-20151006.095547-25 20151006095547 pom 15-20151006.095547-25 20151006095547
Which makes failing some Travis builds on GS master.
Daniele
On Thu, Feb 18, 2016 at 10:53 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140
Geoserver-devel mailing list
And the contents:
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
@jodygarnett
Jody Garnett
@jodygarnett
Ing. Daniele Romagnoli
Senior Software Engineer
So yesterday I changed it to only keep the last 5 snapshots, we also removed all of the maven-metadata.xml files (asking artifactory to regenerate).
I see it is keeping the new build number counting (25). I will set up another support call …
We had two backup plans:
  • install some kind of artifactory plugin that watches the maven logs and deploys based on what it sees being built (sounds sketch to me)
  • cannot remember the second …
On 18 February 2016 at 02:35, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Hi Andrea,
15-SNAPSHOT
20151006.095547
25
20160218071809
sources jar
20151006095547
jar
20151006095547
tests jar
20151006095547
pom
20151006095547
Daniele
Jody Garnett
On Tue, Feb 16, 2016 at 7:34 PM, Jody Garnett <jgarnett@anonymised.com.> wrote:
And the contents:
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
@jodygarnett
Jody Garnett
@jodygarnett
My 2 cents: I would just mercilessly kill the 2015 snapshots, it seems that for some reason artifactory is just
not getting rid of them…
On Thu, Feb 18, 2016 at 8:21 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Hi Andrea,
15-SNAPSHOT
20151006.095547
25
20160218071809
sources jar
20151006095547
jar
20151006095547
tests jar
20151006095547
pom
20151006095547
Daniele
On Thu, Feb 18, 2016 at 10:53 AM, Andrea Aime <andrea.aime@anonymised.com.1268…> wrote:
And the contents:
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
@jodygarnett
Jody Garnett
@jodygarnett
Ing. Andrea Aime
@geowolf
Technical Lead
Chris is gong to run a cleanup job now …
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Hi Andrea,
15-SNAPSHOT
20151006.095547
25
20160218071809
sources jar
20151006095547
jar
20151006095547
tests jar
20151006095547
pom
20151006095547
Daniele
And the contents:
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
@jodygarnett
Jody Garnett
@jodygarnett
Any difference now?
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Hi Andrea,
15-SNAPSHOT
20151006.095547
25
20160218071809
sources jar
20151006095547
jar
20151006095547
tests jar
20151006095547
pom
20151006095547
Daniele
And the contents:
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
@jodygarnett
Jody Garnett
@jodygarnett
Okay working on this one for a moment:
Going in through repo.boundlessgeo.com I get:
https://repo.boundlessgeo.com/snapshot/org/geotools/gt-render/14-SNAPSHOT/
gt-render-14-20160216.183319-1-sources.jar 16-Feb-2016 18:33 427.20 KB
gt-render-14-20160216.183319-1-sources.jar.md5 16-Feb-2016 18:33 32 bytes
gt-render-14-20160216.183319-1-sources.jar.sha1 16-Feb-2016 18:33 40 bytes
gt-render-14-20160216.183319-1-tests.jar 16-Feb-2016 18:33 6.80 MB
gt-render-14-20160216.183319-1-tests.jar.md5 16-Feb-2016 18:33 32 bytes
gt-render-14-20160216.183319-1-tests.jar.sha1 16-Feb-2016 18:33 40 bytes
gt-render-14-20160216.183319-1.jar 16-Feb-2016 18:33 549.25 KB
gt-render-14-20160216.183319-1.jar.md5 16-Feb-2016 18:33 32 bytes
gt-render-14-20160216.183319-1.jar.sha1 16-Feb-2016 18:33 40 bytes
gt-render-14-20160216.183319-1.pom 16-Feb-2016 18:33 6.49 KB
gt-render-14-20160216.183319-1.pom.md5 16-Feb-2016 18:33 32 bytes
gt-render-14-20160216.183319-1.pom.sha1 16-Feb-2016 18:33 40 bytes
maven-metadata.xml 16-Feb-2016 18:33 1.13 KB
maven-metadata.xml.md5 16-Feb-2016 18:33 32 bytes
maven-metadata.xml.sha1 16-Feb-2016 18:33 40 bytes
The contents of maven-metadata.xml are shown as:
20160216.183319
1
20160216183323
sources
jar
20160216183319
jar
20160216183319
tests jar
20160216183319
pom
20160216183319
Does that look fixed?
Checking 15-SNAPSHOT (a more active build) shows more then one snapshot version…
Hi Jody,
nope, still not out of the woods, while this has the right jars:
https://repo.boundlessgeo.com/snapshot/org/geotools/gt-coverage/15-SNAPSHOT/
this one, which is used by the geoserver pom files, still has the old ones:
https://repo.boundlessgeo.com/main/org/geotools/gt-coverage/15-SNAPSHOT/
Maybe it’s just a matter of changing the repositories inside the GeoServer pom file,
but it’s still odd that those old jars are still around:
https://github.com/geoserver/geoserver/blob/master/src/pom.xml#L54
On Thu, Feb 18, 2016 at 11:28 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
20160216.183319
1
20160216183323
sources
jar
20160216183319
jar
20160216183319
tests jar
20160216183319
pom
20160216183319
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks, discovered the reason … we are looking at different things!
Compare:
On 19 February 2016 at 00:43, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Jody,
Jody Garnett
20160216.183319
1
20160216183323
sources
jar
20160216183319
jar
20160216183319
tests jar
20160216183319
pom
20160216183319
Ing. Andrea Aime
@geowolf
Technical Lead
So downstream apps are looking at:
Okay got this on the run now …
  1. https://repo.boundlessgeo.com/snapshot/org/geotools/gt-render/14-SNAPSHOT
  • this is correct and contains the results of the latest build
  1. https://repo.boundlessgeo.com/boundlessgeo/org/geotools/gt-render/14-SNAPSHOT/
  • contained snapshots from October prior to repository being moved
  • we have removed this so it is no longer republished via main
  • will remove appropriate geoserver snapshots as well
  • older snapshots (13-SNAPSHOT for example) will remain for projects that have not upgraded yet
  1. http://maven.geo-solutions.it/org/geotools/gt-render/
  • contains a 14-SNAPSHOT from march
  • being republished via main
  • action: please remove geotools 14-SNAPSHOT, 15-SNAPSHOT
On 19 February 2016 at 10:30, Jody Garnett <jody.garnett@anonymised.com> wrote:
Compare:
Jody Garnett
Jody Garnett
Hi Jody,
20160216.183319
1
20160216183323
sources
jar
20160216183319
jar
20160216183319
tests jar
20160216183319
pom
20160216183319
Ing. Andrea Aime
@geowolf
Technical Lead
Travis CI for GeoScript Groovy is failing because Travis is pulling really
old SNAPSHOT jars. Actually, all of my projects that use GeoTools are
broken on Travis CI right now. They build locally but fail on Travis CI.
Jared
View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-artifactory-ares-jenkins-chat-tp5251329p5251915.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
They are currently pulling from repo.boundlessgeo.com/mainrepo.geosolutions.it
To fix your project please use repo.boundlessgeo.com/snapshots for snapshot releases.
This situation will be fixed when GeoSolutions clears some of their old snapshots from March.
I have been debugging this for some days this week, and fixing one problem left to the snapshots from November being removed, so only now are we seeing these snapshots from a GeoSolutions march build.
On Sun, Feb 21, 2016 at 10:25 AM jerickson <jared.erickson@anonymised.com> wrote:
Jared
Jody Garnett
On Mon, Feb 22, 2016 at 3:53 AM, Jody Garnett <jody.garnett@anonymised.com>
wrote:
They are currently pulling from repo.boundlessgeo.com/main -->
snapshot releases.
We'll try to remove them asap.
Wondering why snapshots from March started causing issues only after the
repo switch though?
(actually, only a few days ago when you removed the october snapshots
leftover from
the old boundless repo)
I guess before you were not mirroring snapshot artifacts from the
geosolutions repo (something
that I don't see the need for, indeed, we never depended on snapshot
artifacts from
jai-ext or imageio-ext afaik).
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Feb 22, 2016 at 8:32 AM, Andrea Aime <andrea.aime@anonymised.com>
snapshot releases.
Removed all snapshots some time ago from the geo-solutions repo (e..g,
http://maven.geo-solutions.it/org/geotools/gt-coverage/ )
but as of now, they are still showing up in the boundless repo:
https://repo.boundlessgeo.com/main/org/geotools/gt-coverage/14-SNAPSHOT/
Do you need to manually remove them?
Ing. Andrea Aime
@geowolf
Technical Lead
I will check now … so the cache from geosolutions is here (https://repo.boundlessgeo.com/geosolutions/org/geotools/gt-coverage/14-SNAPSHOT/) - going to try and ask it filter org/geotools/** and org/geoserver/**.
That worked.
Would it be smart to turn this around, and only focus on caching the it/geosolutions/** artifiacts required for the geotools, geowebcache and geoserver builds?
(If I only cached it/geosolutions/** would I miss anything at this time…)
On 22 February 2016 at 09:42, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
On Mon, Feb 22, 2016 at 8:32 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Removed all snapshots some time ago from the geo-solutions repo (e…g, http://maven.geo-solutions.it/org/geotools/gt-coverage/ )
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Feb 22, 2016 at 3:53 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
We’ll try to remove them asap.
On Mon, Feb 22, 2016 at 7:44 PM, Jody Garnett <jody.garnett@anonymised.com>
wrote:
I will check now ... so the cache from geosolutions is here (
That worked.
geoserver builds?
(If I only cached it/geosolutions/** would I miss anything at this time...)
Nope, that would make you miss everything that jai-ext and imageio-ext
depend onto, which are not in our groupId.
Instead, if you can, do the opposite, and exclude org.geotools and
org.geoserver, or even better, stop mirorring
snapshots
Ing. Andrea Aime
@geowolf
Technical Lead
I have done those three things, exclude org/geotools and org/geoserver and marked this as a release repository.
On 22 February 2016 at 10:47, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
On Mon, Feb 22, 2016 at 7:44 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
That worked.
Nope, that would make you miss everything that jai-ext and imageio-ext depend onto, which are not in our groupId.
Instead, if you can, do the opposite, and exclude org.geotools and org.geoserver, or even better, stop mirorring
snapshots
Ing. Andrea Aime
@geowolf
Technical Lead
The old jar problem went away yesterday, but today it is back. Builds are
failing on Travis CI again.
Jared
View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-artifactory-ares-jenkins-chat-tp5251329p5252685.html
Can you give me a specific example (travis failures are not always the same as old jar failures…).
I did change a setting today (filter **/14-SNAPSHOT/*" to **/14-SNAPSHOT" to try and prevent the now empty directories from being listed.
On 24 February 2016 at 17:04, jerickson <jared.erickson@anonymised.com> wrote:
Jared
Jody Garnett
Sure,
https://travis-ci.org/geoscript/geoscript-groovy
seems to download geotools snapshot jars from 2015:
[INFO] Downloaded:
http://repo.boundlessgeo.com/main/org/geotools/geotools/15-SNAPSHOT/geotools-15-20151006.095401-27.pom
(70 KB at 176.3 KB/sec)
So I end up with compile errors due to missing classes:
[ERROR]
/home/travis/build/geoscript/geoscript-groovy/geom/src/main/groovy/geoscript/geom/Geometry.groovy:[19,34]
1. ERROR in
(at line 19)
  import org.geotools.geometry.jts.OffsetCurveBuilder
Groovy:unable to resolve class org.geotools.geometry.jts.OffsetCurveBuilder
I hope that helps!
Jared
View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-artifactory-ares-jenkins-chat-tp5251329p5252821.html
