Hi Jody,
we noticed that the Windows installer build is green, but no installer is available in the 2.21.5 artifacts uploaded
on SF. For context, it’s also missing in 2.21.4, but for example 2.22.3 (done friday) has it.
I’ve also checked manually, indeed it’s not here:
/var/lib/jenkins/workspace/geoserver-release/distribution/2.21.5
Wondering, maybe the exe is stuck somewhere on the windows server?
Perhaps its
On Mon, May 8, 2023 at 10:11 AM Andrea Aime <andrea.aime@anonymised.com.6887…> wrote:
Hi Daniele,
gave it a spin:
- Startup ok
- All previews work, various formats (OL, GML, GeoJSON, KML)
- Round of admin panels, no issues found
Looks good to me!
On Fri, May 5, 2023 at 1:46 PM Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Hi All,
After doing release 2.22.3 we also took the opportunity to do release 2.21.5 although it was unscheduled.
Please, if you have a chance, try them out and report any issues.
Artifacts for GeoServer release 2.21.5 are available here: https://build.geoserver.org/view/release/job/geoserver-release/119/artifact/distribution/2.21.5/
Daniele Romagnoli
Daniele Romagnoli
Senior Software Engineer
GeoSolutions Group
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Geoserver-devel mailing list
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
