I got a question though, the geoserver geogig community module is just integration between geoserver and geogig datastore. Don’t you also need a backport of the geogig datastore that works with an older version of GeoTools?
On 26 January 2016 at 10:14, Gabriel Roldan <groldan@anonymised.com> wrote:
about backporting to geoserver 2.8.x and 2.7.x…
I could easily do so if the geogig module is allowed to be a Java8 project, cause geogig’s dev branch already moved towards it, and this geogig release shall be cut off what we currently have on the dev branch.
So would that be acceptable?
Jody Garnett
On Mon, Jan 25, 2016 at 12:38 PM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Cool, thanks Gabriel!
-A.
Gabriel Roldán
Software Developer | Boundless
groldan@anonymised.com39…
@boundlessgeo
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via Poggio alle Viti 1187
mob: +39 331 6233686
On Mon, Jan 25, 2016 at 4:21 PM, Gabriel Roldan <groldan@anonymised.com> wrote:
Hey, just a heads up that I’ll be working on getting a geogig release out and moving the geogig geoserver plugin to a community module this week.
Keep tuned, looking forward to make geonode’s life easier.
On Thu, Jan 21, 2016 at 6:26 AM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Master branch is ok. It would be nice to have also the module on the 2.8.x and 2.7.x since GeoNode 2.4 points to GeoServer 2.7.x right now.
Many thanks Gabriel!
Alessio.
Gabriel Roldán
@boundlessgeo
@alfa7691
On Thu, Jan 21, 2016 at 1:20 AM, Gabriel Roldan <groldan@anonymised.com> wrote:
Hi Alessio,
I’m keen to move the geogig geoserver plugin as a geoserver community module.
I’ve heard of the inconveniences its inclusion to the default geonode build brought up, and just for the record want to notice that since I first heard of it I was shocked that it was included in the official geonode build. My position, from a technical perspective, was and is that it should have never been like that.
But yeah, since we’re now pushing for a stable geogig release (meaning appropriate project resourcing in place) lets just do that and try to alleviate the pain after the fact.
BTW, I take it we’ll only create the community module on geoserver’s master branch? “appropriate resourcing” is a relative term
Gabriel
On Wed, Jan 20, 2016 at 3:20 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Thanks Alessio,
We can move the module to geoserver/community - let me sort out who can do so and we will send a seperate email asking for community module shortly.
Please note that the geogig module packages up the geogig datastore, but more importantly adds several configuration screens for managing geogig repositories. When a geogig datastore is published it is actually providing a view of single geogig “branch”, so you may have several datastores configured publishing content from different branches.
I do not think we will need to refactor the code, but the module is quite old and may need to be updated before it is suitable for use with geonode.
On Wed, 20 Jan 2016 at 03:04 Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Dear all,
few time ago, as an active contributor of GeoNode, I rised an issue about the GeoGig Datastore plugin dependencies which may break or block the GeoNode releases.
This may happen because the GeoGig plugin is not part of the standard distribution of GeoServer.
Since this plugin is part of the official distribution of GeoNode, and since Boundless is open to share this code even if is not in a stable state, I would like to ask if there is some volunteer from Boundless to refactor the code a bit a make it available as a GeoServer community module.
On my side I will volunteer to provide GeoNode with the necessary changes in order to update the dependencies and be sure everything works fine.
Alessio Fabiani.
@alfa7691
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140_______________________________________________
Geoserver-devel mailing list
Jody Garnett
Gabriel Roldán
@boundlessgeo
