[Geoserver-devel] asking before doing something strange
After troubleshooting we have a PR for GEOS-10871 which changes the maven configuration of antrun to use a consistent version.
Due to version inconsistencies the version of geoserver released to source forge and deployed to maven were slightly different.
With this in mind I would like to do something strange:
  1. Create a 2.22.2.x branch
  2. Cherry pick this build change
  3. Re-deploy 2.22.2 artifacts to maven
  4. Update the 2.22.x tag to the new revision
There are no java source code changes here; but moving tags and so on is a strange and unusual response to a strange and unusual problem.
Jody Garnett
Hi Jody,
seems like a reasonable solution to me… assuming that step 1 is “create a 2.22.2.x branch off the existing 2.22.0 tag”, right?
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Yes, it has been a while done we had to do this sort of thing. Strictly speaking a branch may not be required as long as the tag is pushed up.
Jody Garnett
