[Geoserver-devel] Asking include GEOS-9321 (json nested limit fix) into 2.16.0
Hi community,
Recently I sent a PR for fixing GEOS-9321 (json nested limit fix) on master. This fix includes json-lib version upgrade to a forked and fixed new release, since the hard-coded limit resides into this library code. Currently new Json-lib Jar is released into Geosolutions maven server, but the plan is having it on OSGeo maven servers as next step.
This is an important fix for complex features usage and for downstream projects, and it is isolated to WFS GeoJSON output max nested objects support. No format, logic or behavior changes.
PR:
https://github.com/geoserver/geoserver/pull/3736
JIRA issue:
https://osgeo-org.atlassian.net/browse/GEOS-9321
So I’m asking permission for including this fix into 2.16.0 release branch.
Thanks.
Fernando Mino
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Fernando Mino
Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
adding a bit more info about this one, this nested JSON limit issue and how to handle has been discussed in this ML:
http://osgeo-org.1560.x6.nabble.com/JSON-Nesting-too-deep-exception-due-to-hard-coded-limit-td5409280.html
As described in the linked thread, this is not a GeoServer limitation, it is a json-lib limitation, in GeoServer we only need to modify the pom.xml.
We forked the lib and implemented the fix discussed on the thread, and make the necessary artifact available for Maven.
That say, we need this fix badly on a few downstream projects that will depend on GeoServer 2.16.0.
Since this is a very isolated bug fix, which doesn’t change any API, he would like to include it on 2.16.0.
Any objection?
Nuno Oliveira
On Fri, 2019-09-06 at 15:28 +0200, fernando.mino@anonymised.com wrote:
Hi community,
PR:
JIRA issue:
Thanks.
Fernando Mino
Fernando Mino
Software Engineer
Geoserver-devel mailing list
[Geoserver-devel@anonymised.comsts.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Nuno Oliveira
experts!
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
We discussed this internally already and I am fine with this approach.
We also need to talk about long term approach to maintain the JSON lib we are talking about.
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
Seems fine to me as it is just a pom change.
+1
Ian
On Fri, 6 Sep 2019, 14:29 fernando.mino@anonymised.com, <fernando.mino@anonymised.com> wrote:
Hi community,
PR:
JIRA issue:
Thanks.
Fernando Mino
Fernando Mino
Software Engineer
Should we fork the JSON lib into the geoserver repository?
I note that forked jars are a little bit of a bother to track for GeoMesa (and other eclipse projects) so I would like to confirm that this is just a GeoServer dependency.
Jody Garnett
Yes, to the best of my knowledge it’s just a GeoServer dependency. Quick check (you can propose and run more thorough ones):
geoserver (master) $ git grep json-lib
src/community/script/groovy/pom.xml: net.sf.json-lib
src/community/script/groovy/pom.xml: json-lib
src/community/security/keycloak/pom.xml: net.sf.json-lib
src/community/security/keycloak/pom.xml: json-lib
src/community/security/oauth2-geonode/pom.xml: net.sf.json-lib
src/community/security/oauth2-geonode/pom.xml: json-lib
src/community/security/oauth2-github/pom.xml: net.sf.json-lib
src/community/security/oauth2-github/pom.xml: json-lib
src/community/security/oauth2-openid-connect/pom.xml: net.sf.json-lib
src/community/security/oauth2-openid-connect/pom.xml: json-lib
src/extension/sldService/pom.xml:
src/main/pom.xml: net.sf.json-lib
src/main/pom.xml: json-lib
src/pom.xml: net.sf.json-lib
src/pom.xml: json-lib
src/release/ext-authkey.xml: json-lib*
src/wfs/pom.xml: net.sf.json-lib
src/wfs/pom.xml: json-lib
geotools (master) $ git grep json-lib
(nothing)
And oh, +1. At some point we’ll have to make a code sprint to upgrade all our json processing to a more
modern library (we have like 3 different approaches, or more, spread around) but I believe that will require
a code sprint.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
We have a fork with the fix here: https://github.com/geosolutions-it/Json-lib/tree/limit-fix-2.4
No issue in copying it once more over to GeoServer
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Dear all,
thank you for the feedback, related issue here:
Pull requests created and reviewed:
I will merged once Travis is happy :slight_smile:
Best regards,
Nuno Oliveira
