[Geoserver-devel] assembly plugin issue
Dear all,
I’m trying to run a build using the assembly:single option, but I’m getting the following error on the gs-platform module:
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-assembly-plugin:3.2.0:single (default-cli) on project gs-platform: Failed to create assembly: Error creating assembly archive war: archive cannot be empty → [Help 1]
I’ve reproduced this both on master and 2.17.x. Did anyone get the same issue?
Best regards,
Marco Volpini
Please use -N as in our build script:
https://github.com/geoserver/geoserver/blob/master/build/build_release.sh#L302
Jody Garnett
Thank you very much for the hint Jody, it works now indeed.
Best regards,
Marco Volpini
Il giorno ven 3 lug 2020 alle ore 01:45 Jody Garnett <jody.garnett@anonymised.com> ha scritto:
Jody Garnett
On Thu, 2 Jul 2020 at 06:29, Marco Volpini <marco.volpini@anonymised.com> wrote:
Dear all,
Best regards,
Marco Volpini
Geoserver-devel mailing list
I am not sure where to document this in the build process, it was a difference when upgrading to a newer version of the assembly plugin. The configuration is being inherited by modules which are not setup to assemble.
I have considered moving the assembly configuration into the release module so that is not picked up across the entire build.
Jody Garnett
