I am trying to implement an asynchronous data extraction mechanism using Geoserver 1.4.0-M2-WCS for the getCoverage operation. I would be interested to know if there is similar work being carried out. I am planning to use message driven POJOs and ActiveMQ as the message broker. Your feedback will be very useful.
Similar work has been carried out by ESA in the past (when requesting large bandwidth requests you have to schedule the handling of your requests for an off peak time, they donated some time to African projects). You may consider using 1.5.x as the base as it is constructed around pojo services ... talk to Justin.
Jody
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
