[Geoserver-devel] authkey community module improvements
we would like to contribute some work done on the authkey community module.
These are the main improvements:
  • ability to add specific configuration properties to AuthenticationKeyMapper implementations: each AuthenticationKeyMapper can define its own specific configuration properties that will be serialized / deserialized with the authentication filter
  • support in the wicket configuration page for AuthenticationKeyMapper specific configuration properties (currently properties are simple strings so a Textfield for each property is shown)
  • a new AuthenticationKeyMapper using an external (configurable) web service HTTP GET call to map an authkey (session token) to a user
Any opinion or suggestion before I prepare the pull request?
Mauro Bartolomeoli
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
Hi Mauro
Sounds cool.
Christian
On Fri, Oct 3, 2014 at 3:52 PM, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com> wrote:
Mauro Bartolomeoli
@mauro_bart
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
I prepared a pull request here: https://github.com/geoserver/geoserver/pull/778
If someone wishes to review.
Thanks
Mauro
2014-10-04 17:09 GMT+02:00 Christian Mueller <christian.mueller@anonymised.com>:
Hi Mauro
Sounds cool.
Christian
@mauro_bart
Mauro Bartolomeoli
@mauro_bart
